Crank-Nicholson solution of 1D heat equation
The discussion focuses on the numerical computation of solutions to the 1D heat equation using the Crank-Nicholson scheme. Participants explore the implementation details, boundary conditions, and potential pitfalls in the numerical method.
  • One participant presents the Crank-Nicholson discretization of the 1D heat equation and describes the matrix formulation for solving it.
  • The same participant seeks advice on implementing boundary conditions and mentions difficulties with a method that involves reducing the matrix size.
  • Another participant suggests that a common mistake is using a first-order finite difference for the derivative boundary condition and recommends using a three-point formula instead.
  • A subsequent reply confirms the suggestion and clarifies that the proposed accuracy refers to the central difference approximation for the derivative.
  • A later post indicates that the original poster's code is now functioning correctly and mentions an extension of the heat equation that incorporates additional terms.
Participants express differing views on the best approach to implement boundary conditions, with some advocating for higher-order approximations while others believe the transient nature of the problem mitigates the issue. The discussion remains unresolved regarding the optimal method for boundary condition implementation.
Participants do not fully resolve the mathematical steps involved in implementing boundary conditions, and there are assumptions about the accuracy of different finite difference methods that remain unexamined.
hunt_mat
Homework Helper
I wish to numerically compute solutions of the 1D heat equation using the Crank-Nicholson scheme:
The equation is:
<br /> \partial_{t}u=\partial^{2}_{x}u<br />
I use the discretisation:
<br /> u_{i+1,j}-u_{i,j}=s(u_{i+1,j+1}-2u_{i+1,j}+u_{i+1,j-1})+s(u_{i+1,j+1}-2u_{i+1,j}+u_{i+1,j-1})<br />
Where s=\delta t/2\delta x. This can be rearranged into the following:
<br /> su_{i+1,j+1}-(2s+1)u_{i+1,j}+su_{i+1,j-1}=-su_{i,j+1}+(2s-1)u_{i,j}-su_{i,j-1}<br />
This is a matrix equation which is tridiagonal and can be solved very easily using matlab's many inbuilt functions.
So suppose I wish to use the following boundary conditions \partial_{x}u(t,0)=\partial_{x}u(t,L)=0 how would I go about doing it? I've heard about people going from an n\times n matrix to an (n-2)\times (n-2), solving that and just adding in the boundary conditions after that? I tried that method but my solution blew up annoyingly.
Any suggestions on what I am doing wrong? My code is here:
Code:
%This program is meant to test out the Crank-Nicolson scheme using a simple
%nonlinear diffusion scheme.
n=2000;m=30;
t=linspace(0,20,n);% set time and distance scales
x=linspace(0,1,m);
dx=x(2)-x(1);dt=t(2)-t(1); %Increments
s=dt/(2*dx^2);%Useful for the solution.
u=zeros(n,m); %set up solution matrix
p=s*ones(1,m-1); q=-(1+2*s)*ones(1,m);
Z=diag(p,1)+diag(p,-1)+diag(q);
A=Z(2:m-1,2:m-1);
%Add in intial condition:
u(1,:)=exp(-5*(x-0.5).^2);
v=zeros(m-2,1);
%Solve the system
for i=2:n-1
    %Construct the RHS for the solution
    for j=2:m-1
        v(j-1)=s*u(i-1,j+1)-(2*s+1)*u(i-1,j)-s*u(i-1,j-1);
    end
    %Solve for the new time step
    w=A\v;
    u(i,2:m-1)=w;
    u(i,1)=u(i,2);
    u(i,end)=u(i,end-1);
end
A common fall is to use first order finite difference for the derivative boundary condition. Use a 3 points formula instead. I don't know how that can be embedded in the solution for the transient problem though.
It shouldn't matter with the transient problem as we're just dealing with boundary conditions. so you're suggesting I use something like:
<br /> \frac{\partial u}{\partial x}\approx\frac{u_{i,j+1}-u_{i,j-1}}{2\delta x}<br />
That's the accuracy you're referring to right?
The code is now working and I have also solved the following extension of the simple heat equation:
<br /> \rho c\frac{\partial T}{\partial t}=\frac{\partial}{\partial x}\left(k(x)\frac{\partial T}{\partial x}\right)+\dot{Q}<br />
  • · Replies 41 ·
10K
