How can I create a accurately-measured conductive strip for electronic projects?
  • Thread starter Thread starter geolej
This discussion focuses on creating an accurately-measured conductive strip for electronic projects, specifically a 5" by 0.5" strip for resistance measurement. Participants suggest alternatives to graphite paint, including stick-on copper strips, printed circuit board tracks, carbon tape, and conductive antistatic foam. The effectiveness of conductive paint is questioned due to its non-conductive binding agents. Techniques for measuring resistance using copper and aluminum foil are also discussed, emphasizing the importance of uniform application for consistent results.
  • Understanding of resistance measurement techniques
  • Familiarity with printed circuit board (PCB) design
  • Knowledge of conductive materials, including conductive paint and copper strips
  • Experience with basic electronic components and tools, such as voltmeters
  • Research the properties and applications of conductive antistatic foam
  • Learn about the use of four-wire measurement techniques for accurate resistance readings
  • Explore the effectiveness of conductive paint markers and their applications
  • Investigate the use of Teledeltos paper for plotting electric fields in electronic projects
Electronics hobbyists, engineers, and designers working on projects requiring precise resistance measurements and conductive materials.
geolej
I am attempting to create a line (5" long by .5") that I can then measure the resistance between. I have tried creating a paint/ graphite mix but no matter what consistency I make by diluting it with acetone, I can't get a accurate distribution of values. They jump erratically when I measure them.
You can get stick-on copper strip. Would this be OK?
Or, you could just have a track like that on a printed circuit board.
If the problem is making contact to the painted strip, maybe you could try painting it between two copper tracks on a printed circuit board and making contact to those for testing.
I have some supposedly conductive paint but it has never been any good. The particles in it are probably conductive but each one gets non-conductive paint around it so the net result is non conductive.
What are you trying to do?
http://grab.by/Sqy
For a glass replacement I have notecards or some bendable object that makes contact with two conductive surfaces, that I can measure the resistance between. Cooper doesn't have enough measurable resistance as far as I know. The end project is a "touchscreen".
What about carbon tape?
Good idea.
I also thought of Teledeltos paper. I don't even know if you can still get it. It was like carbon paper but intended for plotting electric fields.
Also, there is the conductive antistatic foam that you get when you buy integrated circuits. This is conductive but with measurable resistances.
Use thin copper and four wire measurement.
Put 1 amp DC through the copper. (If copper is thick use 10 amp)
Have voltmeter with probes 1 inch apart.
Measure the voltage drop across 1 inch of copper using the probes.
Aluminium cooking foil glued to a suitable flat surface and the aluminium then cut to size.
You might be able to use a conductive paint marker http://www.pemro.com/items.asp?Cc=CONDPEN&iTpStatus=0&Tp=&Bc= they are made with silver in the ink and so are conductive. Also, The Electronic Goldmine has conductive glue http://www.goldmine-elec-products.com/prodinfo.asp?number=G16133 which you might be able to use. I made an electrostatic speaker, and to make the diaphram, I used a piece of projector plastic covered with graphite which was rubbed into the plastic, the trick to getting uniform resistance was to apply the graphite evenly over the film and rub in using another transparency.
  • · Replies 20 ·
  • · Replies 26 ·
  • · Replies 42 ·
