Explaining the Cross Product for Two Vectors
The discussion centers on the mathematical concepts of the cross product and dot product of vectors, specifically addressing the relationship between two vectors, B and C, derived from the cross product of A and B. It is established that the angle between B and C is 90 degrees, as the cross product results in a vector that is orthogonal to the plane formed by A and B. The conversation clarifies that the scalar product of two vectors is a single value, and for two vectors to be orthogonal, their dot product must equal zero. Non-orthogonal vectors do not have a specific term beyond "non-orthogonal."
  • Understanding of vector operations, specifically cross product and dot product.
  • Familiarity with the geometric interpretation of vectors in a Cartesian coordinate system.
  • Knowledge of trigonometric functions, particularly sine and cosine.
  • Basic proficiency in LaTeX for typesetting mathematical expressions.
  • Study the properties of vector orthogonality and their implications in physics and engineering.
  • Explore the applications of cross product in calculating torque and angular momentum.
  • Learn about vector projections and their relationship to dot products.
  • Investigate advanced vector calculus topics, such as gradient, divergence, and curl.
Students of mathematics, physics, and engineering, as well as educators seeking to clarify vector operations and their applications in various fields.
member 731016
Trying to find whether there is a vector that can solve the cross product between two vectors.
Cross product formula: A cross B = ABcos(theta)
Dot product formula: A dot B = ABsin(theta)
Hi!
For this problem,
The solution is,
However, I don't understand their solution at all. Can somebody please explain their reasoning in more detail.
Many thanks!
If ##\mathbf{B} \times \mathbf{A} = \mathbf{C}##, what is the angle between ## \mathbf{B}## and ## \mathbf{C}## (assuming ##\mathbf{C} \neq 0##)?
Thank for your reply! 90 degrees I think because the cross product of two vector is always perpendicular to the plane formed by the two vectors. Many thanks!
Thanks, I see now, so since B and C must be at 90 degrees for it to be a cross product then we take the scalar product to find whether there is any component of B on C or C on B. And the scalar product of all components must be zero if B and C are to be perpendicular. Do you please know what we call it when the B and C are not 90 degrees to each other?Many thanks!
Assuming θ is the angle between the vectors, you have that, ahem, crossed.
##||\vec A\times\vec B||=||\vec A||.||\vec B||.| \sin(\theta)|##
##||\vec A.\vec B||=||\vec A||.||\vec B||.| \cos(\theta)|##.
That wording suggests a misunderstanding. The scalar product of two vectors is a single number. There is not a separate scalar product for each component.
Do you mean for two vectors in general? Maybe "non orthogonal"? Not aware of anything more concise.
##||\vec A.\vec B||=||\vec A||.||\vec B||.| \cos(\theta)|##.That wording suggests a misunderstanding. The scalar product of two vectors is a single number. There is not a separate scalar product for each component.Do you mean for two vectors in general? Maybe "non orthogonal"? Not aware of anything more concise.
Thanks for your reply! Sorry, what did you please mean when you said that we cannot take the scalar product of each component. My textbooks shows:
Many thanks!
Yeah, thanks I mean for any two vectors in general. I think cross product is orthogonal. Many thanks!
Sorry, I didn’t manage to express that quite correctly.
Your remark in post #4 implies you think that if ##\vec x=x_i\vec i+x_j\vec j+x_k\vec k## and ##\vec y=y_i\vec i+y_j\vec j+y_k\vec k## are orthogonal then each of the scalar products ##x_i\vec i.y_i\vec i##, ##x_j\vec j.y_j\vec j##, etc., must be zero. My point is that the scalar product ##\vec x.\vec y## is the sum of those individual products, and it is only that sum that needs to be zero.
All goods, thanks for your reply!
If vectors x and y are not orthogonal, then we can't call it a cross product since the vectors are not at right angles. Is there a specific term used for non-orthogonal vectors?
Many thanks!
Not that I am aware of.
Ok thank you!
Pet peeve: The appropriate LaTeX for the dot product is \cdot. Norms are preferably typeset with \| or \lVert and \rVert.
\vec A \cdot \vec B = \|\vec A\| \|\vec B\| \cos\theta
