CSS3 and HTML5 generator program?
  • Context: HTML/CSS
  • Thread starter Thread starter AliGh
    Generator Program
23 replies · 3K views
AliGh
I'm looking for a program or an IDE which generates HTML5 and CSS3 (Would be better if it could generate some javascript too) any suggestions ?
I saw some websites like : css3generator.com
They are good but i want something that i can use offline and easily accessible
Greg Bernhardt said:
I assume you want free? Otherwise programs like Dreamweaver is an industry standard
Are you sure Dreamweaver has generators like these websites ?
Those programs cannot do magic, you still have to tell them what the website should have. In particular, how can a program know which JS code you want if you don't write the code - apart from a few standard things maybe?
Can you rephrase this?
Sorry my english isn't so good
Are you sure Deamweaver has such features ? I worked with the 2014 version in my friends computer for a few minutes i didn't see such things..
I just want to use the code for appearance not a special function or something
Then why would you need javascript?
You did not see that Dreamweaver generates HTML? What DID you see it do?
EDIT: Hint ... whatever you THINK you saw, what you saw was it generating HTML. Since 2011 it has generated HTML5
I'm just a beginner and haven't tried javascript yet so i don't understand it properly ...
I just want to make sure that i am going to use a good IDE to continue my practicing
I used visual studio code its good for small programs but not for bigger programs
If you only at a beginner stage you would be better off making small projects anyway.
You will want to be able to understand what the various technologies actually do and practice with manual coding and debugging at first.
If you can't do that even for a simple website you won't have much hope maintaining code generated by dreamweaver and other developer studio packages.
I think you need to clearly define what you intend to do and read up on Dreamweaver, because the program is for web design. That is its purpose.
I am practicing PHP and c# for now . I understand what exactly html and CSS do and how they work but i don't have enough time to work on them too
So i need something that generates a code for my pages appearance without me needing to mess around with the code
Dreamweaver will basically allow you to create your webpage visually like a word document (but much much better). You'll be able to edit the actual code if you want and when you need to add the PHP.
Microsoft Expression Web (v4) is free and can be configured to do that. It is my favorite web-dev tool these days. It is also elegant and straightforward to use.
But isn't it limited to Microsoft servers, whereas most web servers run on UNIX / LINUX / APACHE / ETC (i.e. non-Microsoft) or is my understanding out of date ?
Microsoft Expression Web is an editor, and it generates standard code. Visual Studio also generates standard code, and is more up-to-date. The code can then be moved to any type of server.
Ah. I thought it generated some ASP.NET code and was limited to Microsoft. Thanks. (I realize the HTML is universal)
Yeah that is Visual Studio
I just remember the early stuff I read about it said it generated ASP.NET code (in addition to HTML), which I already knew was VS (which I use) and since I wasn't interested in Microsoft-only server code, I ignored it from then on.
Practicing web programming ? You have to clarify your plan (e.g build an e-commerce website like amazon, a blog site that looks like one provided by Word Press, etc), then sketch your pages (brainstorming your ideas), finalize the draft on what are common and variable in each page (this will help you reduce script bloats, esp you will learn where to locate the files that are accessed by all others later). Either backend or frontend, it needs tremendous effort to finish a good site. For ASP.NET, use VS201x and VB.NET or C# of your choice. For PHP it is harder you need a view engine not simply the language built-in methods or commands like echo, print etc (i.e for your backend and frontend to talk to each other in simpler ways), so you may need to use a framework. Both VS 201x and PHP framework include libraries for you to work best to get what you want.
About IDE, I only used Dreamweaver to work in frontend stuff, and used mainly notepad/notepad++ for PHP backend stuff. You can choose NetBeans or Eclipse for PHP if you like; the former works better to me though.
Some years ago, Microsoft's products were not standards-based. FrontPage was a disaster, just for example. But in the interim, Microsoft has moved strongly towards standardization and even openness. Expression Web (which I fear is no longer being developed, in favor of a similar Sharepoint client) IS standards-based, and in both it and Visual Studio, you can tinker with the settings and determine what will be the default version of HTML and CSS that it generates when in WYSIWYG mode. And you can always switch to the code view, which parses according to the standards. Expression Web also has a link-checker and other features that can be very useful. For example, if you change a file name, it will normally correct links within the same web to the new file name.
I develop and maintain websites on both Microsoft and Linux servers, and the Microsoft tools have caused me no issues whatsoever. I do only standards-based code whenever possible.
Both Expression Web and Visual Studio have a very powerful file syncronizer. You can copy a "web" (really, a website) from one site to another, and it will show you which files have changed. Also a very useful feature. Although they both have decent code syntax highlighters, Expression Web has more WYSIWYG power. In Visual Studio, you'll need to code a few things by hand (certain styles and links, for example). It will show you good syntax if you get it right, and bad syntax if you get it wrong, but it won't gen the code for you. Expression Web let's you author as if in Word, and it generates clean code in the background.
Unless I misremember, you can also specify the default character encoding for files, which is important if you are using any foreign language names. I've certainly done my time debugging such issues in the past, and have had little complaint with either.
Although they CAN do FTP, I've always used a separate FTP client (FileZilla) to transfer my files. When I can get it, I've also used the Microsoft Frontpage Server extensions, which let Expression Web and Visual Studio connect directly to servers to edit files and use the built-in file syncing. In recent years, though, it has become less common for sysadmins to tolerate those (it's 3rd-party software), so I'm stuck FTPing again.
I did quite seriously try DreamWeaver but frankly, I always hated it. I was confounded by its user interface, which also changed with each new version. And the last I knew, it was no longer being updated and was no longer up for HTML5 and CSS3.
Visual Studio now supports a variety of different languages out of the box, and even more with added plug-ins.
Right. I tried it. It was just AMAZINGLY awful.
Good to know. Thanks. I use VS extensively, but only for desktop apps in VB.NET, not for my web stuff
I have searched a lot in the internet and i have found some programs :
-Adobe muse
-Quick 'n Easy Web Builder
-Bluementals WeBuilder
Which one is the best ? Adobe muse ? Do you have Any other suggestions ?
