Cubic root code with Numerical Recipes and Cardano method not working
  • Context: Fortran
  • Thread starter Thread starter Amany Gouda
    Cubic Root
6 replies · 3K views
Amany Gouda
I tried to calculate the cubic root by using the method that are exist in Numerical receipes 77 but I got no answer and I don't know my mistake .
Also, I tried by using Cardino method but Also I couldn't success to get an answer.
Can any read my codes and tell me where is my errors or provide me with more ideas.
first code:
Fortran:
! this program is made by using numerical receipes book version 77.
  2 !------------------------------------------------------------------
  3 program main
  4 implicit none
  5 real*8::Q,R,Theta,b,c,d
  6 real*8,parameter::pi=3.14
  7 complex*8::z1,z2,z3,x1,x2,x3
  8 print*,'b,c,d'
  9 read*,b,c,d
 11 Q=((b**2)-(3*c))/9
 12 R=((2*(b**3))-(9*b*c)+(27*d))/54
 15 Theta=acos(R/(sqrt(Q**3)))
 17 x1=-2*(sqrt(Q))*(cos(Theta/3))-(b/3)
 18 x2=-2*(sqrt(Q))*(cos((Theta+2*pi)/3))-(b/3)
 19 x3=-2*(sqrt(Q))*(cos((Theta-2*pi)/3))-(b/3)
 22 print*,'x1=',x1,'x2=',x2,'x3=',x3
 23
 24
 25 z1= sqrt(x1)
 26 z2= sqrt(x2)
 27 z3=  sqrt(x3)
 28
 29
 30 print*,' z1,z2,z3',z1,z2,z3
 31 end program
The second code:
Fortran:
! this program is made to used for calculating the cardino method for the our system parameters.
  2 !-----------------------------------------------------------------------------------------------
  3 program main
  4 Implicit none
  5 Integer::i,a
  6 real*8,dimension (100):: Il,Il2,a0,omega,nominator,dominator
  7 real*8,dimension(100)::f,lamda,kk,sum0,sum1,b,c,d,cardino3,Delta3
  8 real*8,parameter::mass_ratio=0.00870
  9 complex*8,dimension(100)::z1,z2,z3
 11 a=1
 12 Il=0.0
 13 Il2=0.0
 14 sum0=0.0
 15 sum1=0.0
 17 do i =1,100
 19    Il(i)=sum0(i)+0.1
 21    omega(i)=2.359*Il(i)
 22    nominator=2-omega(i)
 23    dominator=1-omega(i)
 24    f(i)=nominator(i)/dominator(i)
 25    lamda(i)=sqrt(f(i))
 26    kk(i)=1/lamda(i)
 27
 28   Il2(i)=sum1(i)+0.001
 29   a0(i)=0.68*Il2(i)
 30
 31    sum0=Il(i)
 32    sum1=Il2(i)
 33
 34
 35   print*,'Il=',Il(i)
 36   print*,'Tl2=',Il2(i)
 37   print*,'omega=',omega(i)
 38   print*,'a0=',a0(i)
 39   print*,'lamda=',lamda(i)
 40   print*,'kk=',kk(i)
 41
 42 call eqn_parameter(omega(i),a0(i),kk(i),b(i),c(i),d(i))
 43
 44    print*,'b=',b(i)
45    print*,'c=',c(i)
 46    print*,'d=',d(i)
 47
 48 call cardino_method(a,b(i),c(i),d(i),cardino3(i),Delta3(i))
 49
 50   print*,' carino_solution',cardino3(i)
 51   print*,'Delta0=',Delta3(i)
 52
 53 call fsub(cardino3(i),b(i),Delta3(i),z1(i),z2(i),z3(i))
 54
 55
 56     print *, "Omega1_square= ",z1(i)
 57     print *, "Omega2_square= ",z2(i)
 58     print *, "Omega3_square= ",z3(i)
 59
 60
 61 end do
 62 end program
 63
 64
 65 subroutine eqn_parameter(x,t,s,f1,f2,f3)
 66     implicit none
 67     real*8,dimension(100),intent(in)::x,t,s
 68     real*8,dimension(100),intent(out)::f1,f2,f3
 69     real*8,dimension(100)::bb,cc1,cc2,cc3,dd
 70
 71     bb=-(2.0+x)
 72     cc1=2.0*x
 73     cc2=2.0*s*t*0.00870
 74     cc3=(1.0d0+cc1-cc2)
 75     dd=-(x+cc2)
 76
 77 end subroutine eqn_parameter
 78
 79
(mentor note: code edited to remove bolding and to use code tags)
Amany Gouda said:
I got no answer
That's too vague. Can you give an example of input and output?
While not related to your problem, this is an eyesore: real*8,parameter::pi=3.14
I'm sure you can do better precision-wise.
Also, the equivalent to real*8 is complex*16.
I mean no output for the cubic root please check the attached file.
the output for the omega square and omega root is zeros.
In the file, I see
Code:
 b=   6.9273636908778262E-310
 c=   6.9532115335400158E-310
 d=   6.9532620141218920E-310
What is the range of a real*8? What do you thinks happens in lines 11 and 12 of the first program?
DrClaude said:
In the file, I see
Code:
For the range, I never think for a range to my result but I thought real*8 represent double precision that mean 64 bit.
DOUBLE PRECISION
REAL (KIND=8)
REAL*8 8 (64 bits) Double-precision real floating-point values in IEEE T_float format ranging from 2.2250738585072013D-308 to 1.7976931348623158D308. Values between 2.2250738585072008D--308 and 4.94065645841246544D--324 are denormalized 3.
for line 11 and 12;
it is a method from the numerical receipes book to get the cubic root by the following steps;
please check page number 179 in the numerical receipes 77;
http://perso.ens-lyon.fr/christophe.winisdoerffer/INTRO_NUM/NumericalRecipesinF77.pdf
I calculated Q and R to get help in calculating the three roots of the cubic equation.
My point is that your are calculating the square and the cube of a number that is ~10-310. The answer will necessarily be zero.
Then please check this modification and tell me where I should consider the range in my new modified code. also, why in MATLAB the same equation produced full results without considering the range.
3 program main
4 Implicit none
5 Integer::i,a
7 real*8,dimension(100)::f,lamda,kk,sum0,sum1,b,c,d,constant_c1,Delta3
10 complex*8,dimension(100)::zz1,zz2,zz3
13 a=1
14 Il=0.0
15 Il2=0.0
16 sum0=0.0
17 sum1=0.0
19 do i =1,100
21 Il(i)=sum0(i)+0.1
23 omega(i)=2.359*Il(i)
24 nominator=2-omega(i)
25 dominator=1-omega(i)
26 f(i)=nominator(i)/dominator(i)
27 lamda(i)=sqrt(f(i))
28 kk(i)=1/lamda(i)
29
30 Il2(i)=sum1(i)+0.001
31 a0(i)=0.68*Il2(i)
32
33 sum0=Il(i)
34 sum1=Il2(i)
35
36
37 print*,'Il=',Il(i)
38 print*,'Tl2=',Il2(i)
39 print*,'omega=',omega(i)
40 print*,'a0=',a0(i)
41 print*,'lamda=',lamda(i)
42 print*,'kk=',kk(i)
44 call eqn_parameter(omega(i),a0(i),kk(i),b(i),c(i),d(i))
45
46 print*,'b=',b(i)
47 print*,'c=',c(i)
48 print*,'d=',d(i)
49
50 call constantc(a,b(i),c(i),d(i),constant_c1(i),Delta3(i))
51
52 print*,' constant_c',constant_c1(i)
53 print*,'Delta0=',Delta3(i)
54
55 call fsub(constant_c1(i),b(i),Delta3(i),z1(i),z2(i),z3(i))
56
57
58 print *, "Omega1_square= ",z1(i)
59 print *, "Omega2_square= ",z2(i)
60 print *, "Omega3_square= ",z3(i)
61
62
63 zz1(i)=sqrt(z1(i))
64 zz2(i)=sqrt(z2(i))
65 zz3(i)=sqrt(z3(i))
66
67 print *, "Omega1_root= ",zz1(i)
68 print *, "Omega2_root= ",zz2(i)
69 print *, "Omega3_root= ",zz3(i)
70
71 end do
72
73 end program
74
75
76 subroutine eqn_parameter(x,t,s,f1,f2,f3)
77 implicit none
78 real*8,dimension(100),intent(in)::x,t,s
79 real*8,dimension(100),intent(out)::f1,f2,f3
80 real*8,dimension(100)::bb,cc1,cc2,cc3,dd
81
82 bb=-(2.0+x)
83 cc1=2.0*x
84 cc2=2.0*s*t*0.00870
85 cc3=(1.0d0+cc1-cc2)
86 dd=-(x+cc2)
86 dd=-(x+cc2)
87
88 end subroutine eqn_parameter
89
90
91 subroutine constantc(aa,be,ci,di,constant_c,Delta0)
92
93 implicit none
94 real*8,dimension(100),intent(in)::be,ci,di
95 real*8,dimension (100),intent(out)::constant_c,Delta0
96 integer::aa
97 real*8,dimension(100)::Delta1,m,BB,mm,CC,NN,cardino1
98 double precision::THIRD= 0.3333333333333333333333333333333333333333333333333333333333333333333333333333333333D0
99
100
101 Delta0= (be**2)-(3*aa*ci)
102 Delta1= (2*(be**3))-(9*aa*be*ci)+(27*(aa**2)*di)
103 m=(Delta0)**3
104 BB=(Delta1)**2
105 mm= BB-(4*m)
106 CC=sqrt(mm)
107 NN=(Delta1+CC)/2
108 constant_c= SIGN((ABS(NN))**THIRD, NN)
109
110
111 end subroutine constantc
112
113 subroutine fsub(g,w,q,u,tt,r)
114
115 implicit none
116 real*8,intent(in),dimension(100)::g,w,q
117 complex*8,dimension(100),intent(out)::u,tt,r
118 complex*8,dimension(100)::z1,z2,z3
119
120 z1=(1,0)
121 u=(-1/3)*(q+(z1*g)+(w/(z1*g)))
122 z2=(-0.5,0.866)
123 tt=(-1/3)*(q+(z2*g)+(w/(z2*g)))
124 z3=(-0.5,-0.866)
125 r=(-1/3)*(q+(z3*g)+(w/(z3*g)))
126 end subroutine fsub
127
