Solving (v+c)^3-3vc(v+c)-(v^3+c^3)=0: What am I Missing?
  • Thread starter Thread starter ali PMPAINT
The discussion centers on solving the cubic equation (v+c)^3 - 3vc(v+c) - (v^3 + c^3) = 0, with substitutions v+c = y, -3vc = p, and v^3 + c^3 = q. Participants identify a sign error in the equation, clarifying that -(v^3 + c^3) should be +(v^3 + c^3). The conversation also delves into the cube roots of unity, specifically w_0, w_1, and w_2, and their polar forms, which are essential for finding all solutions to cubic equations. The correct solutions for x^3 + 2x - 3 = 0 are confirmed to include complex roots, emphasizing the importance of accurate calculations and understanding of polar forms.
  • Cubic equations and their properties
  • Complex numbers and polar forms
  • Cube roots of unity
  • Polynomial division techniques (synthetic division)
  • Study the derivation and application of the cubic formula for solving cubic equations
  • Learn about the properties and applications of cube roots of unity in polynomial equations
  • Explore the use of synthetic division for finding polynomial roots
  • Investigate the relationship between complex numbers and their polar representations
Mathematicians, students studying algebra, and anyone interested in solving cubic equations and understanding complex numbers.
ali PMPAINT
the answer to y^3+py+q=0
So, you can prove it by using (v+c)^3-3vc(v+c)-(v^3+c^3)=0, where v+c=y and -3vc=p and v^3+c^3=q. The problem is, when I try to solve a one, I just get one answer(it should be 3) and I don't know what the article meant by wi. What am I missing?
ali PMPAINT said:
, post: 6177224, member: 661503"]
Problem Statement: the answer to y^3+py+q=0
Relevant Equations: Picture
I think you have a sign error. ##-(v^3 + c^3)## should be ##+(v^3 + c^3)## according to the substitution you show
It says that ##w_i## is one of the cube roots of unity (1). In polar form these are
##w_0= 1##
##w_1 = \cos(\frac {2\pi}3) + i\sin(\frac {2\pi}3)##
##w_2 = \cos(\frac {4\pi}3) + i\sin(\frac {4\pi}3)##
Notice that two of these roots are complex.
If you raise any of these to the 3rd power, you get 1.
Mark44 said:
I think you have a sign error. −(v3+c3)−(v3+c3)-(v^3 + c^3) should be +(v3+c3)+(v3+c3)+(v^3 + c^3) according to the substitution you show.
... or that should say: ##\ -(v^3+c^3) = q \, . ##
Also, for the casual reader, this expression, given by OP, is an identity : ##\ (v+c)^3-3vc(v+c)-(v^3+c^3)=0\, . ##
Yes, thanks for correcting me.
##w_0= 1##
So, I am now familiar a lot with polar form, so if we got an answer like 1 for example, do you set it equal to e^(ix)=cos(x)+isin(x) ?
ali PMPAINT said:
Yes, thanks for correcting me.So, I am now familiar a lot with polar form, so if we got an answer like 1 for example, do you set it equal to e^(ix)=cos(x)+isin(x) ?
Here x is 0, so ##e^{i0} = \cos(0) + i\sin(0) = 1 + i0 = 1##
Yes, but what about the other two answers?
For example, how to get all solutions for x^3+2x-3=0 ?
do you know what synthetic division is?
You included the formula in your first post of this thread. I gave you all three roots of unity in my previous post. Just use that formula, once for each of ##w_0, w_1, w_2##.
ali PMPAINT said:
##w_0= 1##
So, I am now familiar a lot with polar forms, so if we got an answer like 1 for example, do you set it equal to e^(ix)=cos(x)+isin(x) ?
You can get ##w_1## by letting x = 2π/3 in the polar form you gave, which was: e^(ix)=cos(x)+isin(x)
Then ##w_1 = \cos(\frac {2\pi}3) + i\sin(\frac {2\pi}3)## which is the same as ##\displaystyle e^{2\pi i / 3} ##
It then follows that ##\displaystyle {w_1}^3=\left( e^{2\pi i / 3} \right) ^3 = e^{2\pi i } =1 ##
Thanks, but now I'm facing another problem. When I tried to solve for x^3+2x-3=0 I got:
243371
I calculated it with a calculator and I got 1 out of this mess(which is true). No matter what I do, I can't simplify the expresion to get 1. And, I found that the other two roots are number 2 (by both calculator and another methods), but I tried to multiply it with ##w_1 = \cos(\frac {2\pi}3) + i\sin(\frac {2\pi}3)## with one, but I got a wrong result (-1/2+i 3^(0.5)/2 ) which is wrong. Where am I making a mistake?
I am sorry if I am asking a lot, but I really want to know how to solve cubic equations by radicals.
Yes, 1 is a solution of the equation ##x^3 + 2x - 3 = 0##, because if you replace x by 1, you get 0 = 0, which is a true statement.
However, 2 is not a solution of this equation, despite what your calculator and another method imply. The reason is that if you replace x in the equation by 2, you get ##2^3 + 2(2) - 3 = 9 \ne 0##.
Knowing that x = 1 is a solution, that means that (x - 1) is a factor of ##x^3 + 2x - 3##. If you divide the cubic polynomial by (x - 1), either by long division or by synthetic division that @StoneTemplePython mentioned, you get a quadratic polynomial that you can break down using the Quadratic Formula. The other two solutions of your equation are complex.
Yes. the above expression gives you 1 (unity).
It looks like the given expression is incorrect.
The correct results for the two complex solutions to ##x^3+2x-3=0## are ## \displaystyle x= \frac{-1 \pm i \sqrt{11}\,}{2} \,.##
A correct form for the solution to the cubic equation: ##x^3+px+q=0## is:
## \displaystyle w_k \left({\sqrt[{3}]{-{q \over 2}+{\sqrt {{q^{2} \over 4}+{p^{3} \over 27}}}}}+ w_k{\sqrt[{3}]{-{q \over 2}-{\sqrt {{q^{2} \over 4}+{p^{3} \over 27}}}} }\ \right) \ ,
\\ \displaystyle \text{where } w_k=e^{2k\pi i /3} \ .##
Note that for ##k \in \{1,\,2,\,3\,\},\ \ w_k ## is one of the three cube roots of unity.
The above may be expressed in a variety of forms.
Oh yes, my bad, apparently I calculated the roots of x^3-3x+2=0 instead of x^3+2x-3=0 and missed the sign (don't blame me, they are too similar)
So, I think that I had a mistake in my proof, and it doesn't give me a correct answer for more than two answers:
243474
Where is my mistake?
  • · Replies 17 ·
