Which Diagram Shows Accurate Current Flow?
The discussion centers on understanding current flow in a circuit with a battery and a lightbulb. Participants clarify that current does not weaken as it travels through the circuit; it remains constant throughout. The analogy of a pipe filled with sand illustrates that while the lightbulb uses energy, the current itself does not decrease. The key point is that the magnitude of the current is uniform in both wires before and after the lightbulb. Overall, the current stays the same despite the lightbulb lighting up.
krnhseya
There are 4 diagrams for this questions. Which one do you think it's true?
(The diagram has a battery with a lightbulb attached to it)
N/A
I think that the current flows from one end to other end but not sure if the current gets weaker or current stays the same.
I am thinking that the current gets weaker due to the current used to light the lightbulb, which I think it's the way to calculate the voltage.
Current in a wire does not "get weaker" as you go along the wire. If it did, charge would accumulate at some points because it would be moving slow at some points and fast at others.
Think of it like a pipe of sand with a piston at one end, and a little windmill (sandmill, in this case!) that turns as the sand pushes it. The sand is like the charge carriers (electrons), the windmill is like the light bulb. As we push the piston with constant velocity, the windmill spins, but the current of sand -- basically, the sand per unit time, or sand velocity -- remains the same along the pipe. If it didn't, the sand would continue to bunch up at some points where the current of sand is slower, which doesn't make much sense. The current of sand, therefore, has to be uniform along the pipe.
So...it should be...
The electric current is in the direction shown(one end goes through the light bulb and goes back to other end of the battery), and the magnitude of the current is the same in both wires 1(wire before the light bulb) and 2(wire after the light bulb)...?
So the current stays same even though the current causes the light bulb to light up?
I will really appreciate if someone can help me with this "simple" problem.
Can't really help without knowing what you're looking for
It's basically asking if you attach battery to light the light bulb,
do you lose the current by lighting up when the current returns after going through the light bulb
or does the current stay the same throughout the whole circuit?
