Current State of Nuclear Fusion Power
The discussion centers on the current state of nuclear fusion power, exploring the historical predictions about its commercial viability, the challenges faced in achieving fusion energy, and the implications of funding on research progress. Participants reflect on past expectations and the ongoing difficulties in the field, including technical hurdles and funding issues.
  • Historical
  • Some participants recall predictions from the 1970s and 1980s that commercial nuclear fusion would be achieved within a decade, questioning what has delayed progress.
  • There is a consensus among some that the technical challenges of achieving net power gain in fusion are more complex than initially anticipated, including issues like radiation losses and plasma turbulence.
  • Others argue that funding has been insufficient compared to the needs of the research, with historical requests for funding being significantly higher than what was actually received.
  • Some participants suggest that the difficulties faced by plasma physicists were expected, but the pace of progress has been much slower than hoped due to funding constraints.
  • The National Ignition Facility is mentioned as an example of a well-funded project that has not yet achieved its goals, raising questions about the reliability of funding as a solution to the challenges in fusion research.
  • There are differing views on the confidence levels among researchers regarding the success of various fusion projects, with some expressing skepticism about the feasibility of achieving ignition.
  • Concerns are raised about the unrealistic nature of past predictions regarding the timeline for commercial fusion, suggesting that these projections may not have been grounded in the realities of funding and project timelines.
Participants express a range of views on the reasons for the slow progress in nuclear fusion, with some agreeing on the complexity of technical challenges while others emphasize funding issues. There is no clear consensus on the primary factors contributing to the current state of fusion research.
Participants note that funding levels have historically not matched the ambitious goals set by researchers, and there are unresolved questions about the management and expectations of large-scale fusion projects.
  • #32
consuli said:
That's so far the most developed (excess) power generating fusion reactor, I guess.
How did you conclude that? Where is a report that it is generating power at all? All the report says is what it could do if it works.
  • #33
consuli said:
The article title doesn't look very close to me to the title you gave the link. The part you are citing is a 4 year old announcement that as far as I'm aware hasn't been updated.
My first reaction to the title - LMCO has a patent - was: only one?
  • #34
If you are further interested in the Lockheed Martin compact fusion reactor, you have to research on your own.
<< Post edited by a Mentor >>
  • #35
I have researched it, and I've concluded that it is "vaporware". There is no evidence that the concept works at all. The claim that they can run at a beta ratio of 1 is particularly suspect. If instead of looking at the "projections" of what the concept could do, you look at what they have actually achieved, you quickly conclude that they are nowhere close to any kind of viable fusion reactor.
  • #36
phyzguy said:
If (...) you look at what they have actually achieved, you quickly conclude that they are nowhere close to any kind of viable fusion reactor.
I can neither confirm nor deny this, as currently the necessary amount of proof in favour or against is missing. We simply do not know.
  • #37
The burden of proof is on the claim, not on disproving it. If there is not the necessary amount of proof in favor then they have nothing until they can demonstrate otherwise
  • #38
The World Nuclear Association has a good summary of program, both past and current.
From the Wikipedia article on JET
The main source of heating in JET is provided by two systems, neutral beam injection and ion cyclotron resonance heating. The former uses small particle accelerators to shoot fuel atoms into the plasma, where collisions cause the atoms to ionize and become trapped with the rest of the fuel. These collisions deposit the kinetic energy of the accelerators into the plasma. Ion cyclotron resonance heating is essentially the plasma equivalent of a microwave oven, using radio waves to pump energy into the ions directly by matching their cyclotron frequency. JET was designed so it would initially be built with a few megawatts of both sources, and then later be expanded to as much of 25 MW of neutral beams and 15 MW of cyclotron heating.[36]
JET's power requirements during the plasma pulse are around 500 MW[37] with peak in excess of 1000 MW.[38] Because power draw from the main grid is limited to 575 MW, two large flywheel generators were constructed to provide this necessary power.[38] Each 775-ton flywheel can spin up to 225 rpm and store 3.75 GJ.[39] Each flywheel uses 8.8 MW to spin up and can generate 400 MW (briefly).
Ref: https://en.wikipedia.org/wiki/Joint_European_Torus
A practical fusion system must have a self-sustaining fusion-based plasma, and a net electrical energy production, not just breakeven. We're not there yet.
A rather negative and pessimistic assessment from a Forbes contributor.
https://www.forbes.com/sites/quora/...ssible-its-been-done-repeatedly/#40bcaef84cfd
  • #39
Exactly. if I claim that I have a working warp drive, and take weekend trips to Alpha Centauri, do you believe me because there is no proof that I'm wrong?
  • #40
Thread is closed temporarily for Moderation and cleanup...
  • #41
After some cleanup, thread is re-opened.
  • #42
You are absolutely right - from the scientific point of view. Especially, as it would be magnitudes too much work to disprove any claimed theory.
However, the case of the Lockheed Martin compact fusion reactor is difficult. These guys are most probably working under militarily classified conditions. I guess, they would like to prove their fusion theory, but they might not be allowed to do so.
Thus, I cannot take the Lockheed Martin compact fusion reactor as a proven theory. However, I do not like to badmouth it either. Especially for the reason, that usually any scientific project turns out to be more difficult during its realization and I do not want to deprive those half-military researchers their follow-up funding options (by guessing from a bad information basis).
  • #43
I doubt that. If it were part of a classified project, they wouldn't be making public announcements about it. Most such projects you only hear about after they are over.
  • · Replies 19 ·
  • Poll Poll
  • · Replies 18 ·
  • · Replies 20 ·
24K
