Curvature polynomials vanish for plane waves?
The forum discussion centers on the properties of curvature polynomials in the context of plane wave solutions in general relativity, specifically referencing Geroch's 1968 paper on curvature invariants. It is established that all type I curvature invariants vanish for plane wave solutions, despite the Riemann tensor being non-zero. The discussion also highlights the implications of this phenomenon, including the potential for singularities formed by colliding plane waves and the challenges in measuring curvature invariants in the absence of matter or reference frames.
  • Understanding of curvature invariants in general relativity
  • Familiarity with Geroch's work on singularities and curvature
  • Knowledge of Riemann and semi-Riemannian geometry
  • Basic grasp of gravitational wave properties and their mathematical representation
  • Study Geroch's paper "What is a singularity in general relativity?" for foundational concepts
  • Explore the implications of curvature invariants in gravitational wave physics
  • Investigate the differences between Riemannian and semi-Riemannian geometries
  • Examine the concept of diffeomorphisms in the context of curvature tensor behavior
Researchers, physicists, and students in the field of general relativity, particularly those focusing on gravitational waves, curvature invariants, and the mathematical underpinnings of singularities in spacetime.
bcrowell
Staff Emeritus
Insights Author
Geroch 1968 touches on the Kundt type I and II curvature invariants. If I'm understanding correctly, then type I means curvature polynomials. Type II appears to be something else that I confess I don't understand very well. (I happen to own a copy of the book in which the Kundt paper appeared. I looked at the paper, and I can't make heads or tails of it.) Geroch says, "For example, in the plane wave solutions all the type I invariants vanish, yet the Riemann tensor is not zero."
This seems very surprising to me. Am I understanding correctly that all curvature polynomials vanish in the case of a plane wave solution? Why would this be?
Geroch, "What is a singularity in general relativity?," Ann Phys 48 (1968) 526
The paper Hans-Jürgen Schmidt, Why do all the curvature invariants of a gravitational wave vanish?, http://arxiv.org/abs/gr-qc/9404037 gives an argument based on form-invariance of the metric under a boost along a null direction and the fact that the curvature invariants are continuous functions of their arguments.
Thanks, that's an extremely interesting paper, despite the sometimes unintelligible English. It's going to take me some time to digest. I hadn't realized that the Riemannian and semi-Riemannian cases were so different from each other.
Very interesting, also the paper in post 2. Is the following possible or is there an "obvious" reason for it not to work? To have two plane waves coliding and forming a singularity (with or without black hole) and thus a physically reasonable example of a singular space-time with all curvature scalors regular (in fact zero).
Hmm...but the field equations are nonlinear, and the formation of a singularity is about as spectacular a nonlinearity as one could imagine. So I would expect that the curvature scalars would not be zero in this situation.
But a single plane wave can be singular: https://www.physicsforums.com/threads/wave-of-death.93654/#post-1176988
I'm puzzled by this remark in the Schmidt paper:
In the absence of matter or reference systems - only curvature invariants are locally constructively measurable.
He seems to give this as motivation for being interested in curvature invariants. But I don't know what "constructively" measurable means, or whether he has some precise meaning of "locally" in mind. LIGO clearly can't be designed to measure curvature scalars, since what it's designed to detect is a plane wave. I don't understand why it would be of interest to talk about measurements in the absence matter or of a frame of reference; ordinarily your measuring apparatus is material and has its own well-defined rest frame.
Geroch gives this instead as motivation for curvature invariants:
...in any spacetime which is not of constant curvature, one can always choose a frame in which the physical components of the Riemann tensor become infinite on approaching any point.
I don't understand this either. When we change frames, the change of coordinates can be represented as a diffeomorphism. If the components of a tensor are finite in one set of coordinates, then they remain finite under a diffeomorphism.
Schmidt defines curvature invariants and generalized curvature invariants. I think Kundt's type II are ratios of curvature polynomials, and these do not qualify as curvature invariants according to Schmidt's definition, since they depend in a discontinuous way on the curvature components (the denominator can go to zero).
I think I understand this now. Schmidt's proof doesn't depend on signature, and is valid in 3 or more dimensions. However, the physical content is easiest to understand in 3+1 dimensions. Here we have gravitational waves, and the argument is basically that when we redshift a gravitational wave, in the limit of arbitrarily large redshifts, all of the components of the Riemann tensor, as well as their derivatives, approach zero. If the curvature invariant is a continuous function of these components, then it also approaches zero. But it's a scalar, so it has to be invariant under boosts, and therefore it vanishes identically.
As a side note, Schmidt seems to claim at the bottom of p. 3 that for a Riemannian signature, the space is flat if and only if the Kretschmann scalar vanishes. I'm assuming this is a problem with his tortured English, because it would seem to contradict the main result of his paper, in which he constructs an explicit counterexample in 3 dimensions for arbitrary signature. He says "If the metric has definite signature or if n=2...," but I think the "or" has to be wrong, doesn't it?
The exmale is for indefinite matrics of any signature. By the way what is $I_0$? It seems to be defined as the sing of a sum of absolute values!
Which would contradict what he says at the bottom of p. 3, right?
It simply equals 0 if the Riemann tensor is zero, 1 otherwise.
Oh, now I think I get the point about the signature. I wasn't understanding his terminology ("indefinite"=not Riemannian) correctly. His results really don't apply to Riemannian signatures at all. His metric ##ds^2=2dudv\pm a^2 dw^2## has signature +-- or ++-, depending on the choice of sign on the ##dw^2## term, but either way, it's not a Riemannian signature.
After thinking about this a little more, I think the idea is that you can have badly behaved coordinates, which are not related by diffeomorphism to the well-behaved coordinates. For example, the Riemann tensor for the Schwarzschild metric, expressed in Schwarzschild coordinates, has a component ##R_{\theta rr\theta}=m/(r-2m)##, which blows up at the event horizon. We can get rid of this divergence by a change of coordinates, but not by a diffeomorphism. Going the opposite way, we can introduce a blow-up in the Riemann tensor. E.g., the change of coordinates from Kruskal–Szekeres coordinates to Schwarzschild coordinates has ##\partial r/\partial X=\partial r/\partial T=0## at the horizon, so it's not a diffeomorphism.
12K
  • · Replies 41 ·
