Curve fitting and least squares method.
2 replies · 4K views
danbone87
I have an equation as a function of time. (eq1) C(t) = Css + a(e^.5t) + b(e^.9t) t>0
Where, Css is a constant. then I have 6 data points of time and C (Concentration of a liquid)
1. I have to find an equation to find the maximum time and contains a, b and Css.
2. I have to show the complete least squares derivation based on equation 1 as the approximating function.
First of all, I'm wondering what the difference between 1 and 2 are... both are ways to find tmax. Also, when doing a least squares method, I don't know exactly how to decide what to type of equation to choose to find my a, b and Css. Will a polynomial work since this function involves exponentials... and how would i decide what degree polynomial to use? Since I should have 3 systems of equations should I go up to a third degree polynomial?
Hi, I have an update!
For part 1. I realized from long ago that the max and mins of a function occur when y'=0
So I took the derivative of the function which gave me
c'(t)= .5a(e^.5t)*(e^.5t) + .9b(e^.9t)*(e^.9t) = 0
i took the ln of the whole thing
and that gave me
[ln(.5a)*.5t + .5t] + [ln(.9b)*.9t + .9t] = 0
my question now is can use the property that ln(xy) = ln(x)+ln(y) to combine the two ln's and thereby combining the coeffiecients of t such that it is .5t+.9t = .14t
and the whole thing would be .14t*ln(.45ab)= -.14t
... that seems to be wrong considering that the t's cancel out but I can't think of much else...
If you are still looking for help, you need to look at the purpose of least squares, which is to minimize the sum of the squares of the vertical distance between the data points and the fitting function:
[tex]min \ g= \sum_{i=1}^n[f(a,b,t_i) - y_i]^2[/tex]
Where a and b are the unknown coefficients of the fitting function. To minimize, take the partial derivative of g with respect to each unknown. When terms are collected, the result is a set of simultaneous linear equations that can be solved for a and b.
