- 37,031
- 16,053
And when the deviations from flatness are significant then, by definition, you cannot compare distant velocities.
Would this be due to the fact that in GR there isn't even an unambiguous way to compare in general the ticking "rates" of inertial clocks, which leads us to not being able to compare velocities since for doing that you need an agreement about the proper time of the objects whose velocity you want to compare?DaleSpam said:And when the deviations from flatness are significant then, by definition, you cannot compare distant velocities.
TrickyDicky said:Would this be due to the fact that in GR there isn't even an unambiguous way to compare in general the ticking "rates" of inertial clocks, which leads us to not being able to compare velocities since for doing that you need an agreement about the proper time of the objects whose velocity you want to compare?
In the case of "nearly flat" scenarios with no significant curvature where you have the objects paths sharing two events, you can compare their velocities, right?
I'm just starting with the study of GR and wanted to check if I understand anything at all
Take a simple example of a 1 meter rod free falling radially in the length in a Schwarzschild spacetime. Gravitation will cause an inertial acceleration between the front and the back of this rod (and of course everything in between). If it gets stretched do you consider the rod to be still one meter long? If the rod is very strong and accelerates everything inwards (proper acceleration!) to maintain its structure is the distance between the ends still one meter? How do you even want to define a meter in this situation?TrickyDicky said:Would this be due to the fact that in GR there isn't even an unambiguous way to compare in general the ticking "rates" of inertial clocks, which leads us to not being able to compare velocities since for doing that you need an agreement about the proper time of the objects whose velocity you want to compare?
Passionflower said:Take a simple example of a 1 meter rod free falling radially in the length in a Schwarzschild spacetime. Gravitation will cause an inertial acceleration between the front and the back of this rod (and of course everything in between). If it gets stretched do you consider the rod to be still one meter long? If the rod is very strong and accelerates everything inwards (proper acceleration!) to maintain its structure is the distance between the ends still one meter? How do you even want to define a meter in this situation?
You see that even in a simple scenario we could already get issues with distance.
Just refresh as the preview is showing cached images.Anamitra said:I have been having a big problem with the Latex toolbar provided by the forum. Every time I am writing something I am getting a different preview. But I am not having any such problem with the one I use on the MS word editor.I really don't know what to do and I am ready to take any advice.
If you are not comfortable with the refresh as an alternative use a latex editor (such as Led) veryy that your equations are right and them simply cut and paste. There is actually no need to use the toolbar it is only there for convenience.Anamitra said:I will start using the forum Latex tool bar at my earliest.
A local inertial frame is not unique. There are an infinite number of such frames. If you go on different chains of inertial states you may still wind up with different final inertial frames and different final vectors. A chain of locally inertial frames is not sufficient to establish uniqueness. The argument is not as strong as you seem to believe.Anamitra said:I thank you for the example.
[But then again if you refer to a chain of inertial states there is no problem at all]. I have a very strong point here.[Please refer to the attachment]
You can test this out for yourself. Simply take the Schwarzschild metric and do a similar exercise to what I suggested earlier. Set t and r to some constant values (r outside the event horizon) and calculate the parallel transport of a vector around some lattitude line, eg 45º.Anamitra said:Now my further confusions[I am simply trying to get my own ideas clear]:
1)I would like to refer to three vectors now. We represent a four dimensional space-time surface by f(x,y,z,t)=0 --------------- (1)
We may split the four dimensional space into a product of two spaces--a three dimensional space consisting of the variables x,y and z and a time space.The three dimensional space cannot have a surface restriction. Say it had some restriction like z=f1(x,y) .Then we could have substituted the value of z by f1(x,y) and reduced the number of variables in equation (1). It is a well known fact that a three dimensional region becomes a surface in the four dimensional space.What I would like to emphasize is that there is no surface restriction on the three dimensional region and parallel transportation of a three dimension vector should be quite "classical" in its mode.There should be no problem at all in adding or subtracting vectors at a distance.I would like you to consider the threads #40 ,#57 and #60
Links: https://www.physicsforums.com/showpost.php?p=2849247&postcount=40
https://www.physicsforums.com/showpost.php?p=2850358&postcount=57
https://www.physicsforums.com/showpost.php?p=2850394&postcount=60
DaleSpam said:A local inertial frame is not unique. There are an infinite number of such frames. If you go on different chains of inertial states you may still wind up with different final inertial frames and different final vectors. A chain of locally inertial frames is not sufficient to establish uniqueness. The argument is not as strong as you seem to believe.
Then confidently work the problem. If you really are interested in learning then you will find it a valuable exercise. If you just have some sort of weird agenda to promote then I won't waste my time any longer.Anamitra said:I claim with full confidence ...
Show your work. The last three posts are just so much static noise until you do.Anamitra said:Both the vectors return to their original position without any change of orientation.
TrickyDicky said:In the case of "nearly flat" scenarios with no significant curvature where you have the objects paths sharing two events, you can compare their velocities, right?
