Cutting metal pipe to make different pitches
  • Context: High School
  • Thread starter Thread starter ltt
    Cutting Metal Pipe
This discussion focuses on determining the appropriate lengths for cutting metal pipes to produce specific musical pitches, specifically E, D, C, and G, for the song "Mary Had a Little Lamb." The outer diameter of the pipes is specified as 1 inch. Key resources include mathematical formulas for pipe length calculations and frequency charts, which are essential for achieving the desired pitches. The discussion highlights that while the length of the pipe is the primary factor for organ pipes, the inner diameter, wall thickness, and material properties significantly influence the sound produced by wind chimes.
  • Understanding of pipe length calculations for musical notes
  • Familiarity with the relationship between pipe dimensions and sound frequency
  • Knowledge of material properties affecting sound resonance
  • Basic principles of acoustics in musical instruments
  • Research mathematical formulas for calculating pipe lengths for specific musical pitches
  • Explore the impact of inner diameter and wall thickness on sound frequency
  • Study the design principles of wind chimes and their acoustic properties
  • Examine frequency charts for musical notes to enhance understanding of pitch production
Musicians, pipe organ designers, and hobbyists interested in constructing musical instruments or optimizing sound production through metal pipes.
ltt
Hi, we are trying to make different pitches by cutting metal pipes at different frequincies to produce different pitches. We don't know how to determine the length at which we should cut the pipes. We want to play notes E, D, C, G to play mary had a little lamb. the outer diameter of the pipe is 1 in. Please help us with our project. Thank you :)
Pipe organs designers have same need ... here's the math ...
http://www.rwgiangiulio.com/math/pipelength.htm
The math should work for xylophone-like striking (ie windchimes) for shorter lengths
Inside diameter of pipe must have some effect ... for air supplied resonance, ID should affect wave amplitude. If struck then ID, wall thickness, and material properties all will be factors.
Musical notes to frequency chart ...
http://www.phy.mtu.edu/~suits/notefreqs.html
No, that won't work. For an organ pipe, the air inside the pipe is vibrating. For normal atmospheric conditions, the most important parameter is the length of the pipe, though the diameter has a small effect. The material of the pipe doesn't affect the pitch.
For a wind chimes, the actual metal of the pipe is vibrating like a cantilever beam. The frequency depends on the material and the diameter and wall thickness of the pipe, as well as the length.
There is a lot of information on designing wind chimes here: http://home.fuse.net/engineering/Chimes.htm
  • · Replies 22 ·
  • · Replies 20 ·
11K
