D: S --> Z, the string of all 1's and zeros
  • Thread starter Thread starter jonroberts74
    String
The function D: S --> Z, defined as the difference between the number of 1's and 0's in binary strings, is not one-to-one (1-1) because different strings can yield the same result, such as D(111000) and D(110100), both resulting in 0. However, D is onto, meaning for every integer k, there exists a string s in S such that D(s) = k; for example, a string of k 1's has D(s) = k, a string of k 0's has D(s) = -k, and a balanced string has D(s) = 0. The discussion emphasizes the need to find specific examples for each case of k to demonstrate the onto property effectively. Overall, the function D successfully maps the set of binary strings to all integers.
jonroberts74
Let S bet the set of all string's of 0's and 1's. define D: S --> Z as follows : for all s in S, D(s) = the numbers of 1's in s minus the number of 0's in s.
a) Is D 1-1? Prove or give counterexample
b) Is D onto? Prove or give counter example
a) seems easy enough.
D(s_{i}) = 5[ones]-5[zeros]=0; s_{i} \in S
D(s_{j}) = 6[ones]-6[zeros] = 0; s_{j} \in S
s_{i} \neq s_{s}
thus not 1-1
b) It seems to be true.
only proof I could think up would to be
let s_{k} \in S such that the numbers of ones is and zeros in s_{k} is k_{1}, k_{0} \in \mathbb{Z} respectively.
now, D(s_{k}) = k_{1} - k_{0}
and because integers have closure under subtraction k_{1} - k_{0} = k_{z} such that
k_{z} \in \mathbb{Z}
therefore D(s) is an onto function
This is not correct. You need to show that for any k \in \mathbb{Z} there is an s in S such that D(s) = k.
let k \in Z such that D(s) = k
this is where I am stuck now. If I were dealing with a function like f(x) = y = 4x-1. I would solve for x, substitute that in and I'd be able to solve to get back to y.
here I have D(s) = k = [number of ones] - [number of zeros]
No. You start by taking an arbitrary ##k \in \mathbb{Z}##. Then you need to find a string ##s## in ##S## such that ##D(s) = k##. Can you find such a string?
let k be any integer
let s in S have (k+j) ones and j zeros
now,
D(s) = (k+j) - j = k
jonroberts74 said:
let s have (k+j) ones and j zeros
You are on the right track, but what is ##j## here? Do you need it? It might also help if you consider the cases ##k>0##, ##k<0## and ##k=0## separately.
If k > 0 then number of ones > number of zeros
if k = 0 then number of ones = the number zeros
if k < 0 then number of ones < number of zeros
and so j is the value difference between number of ones and number of zeros. I'm not sure How I could show it without using it.
I don't mean to butt in, but I think you're maybe trying to be a little too general and making this more difficult than it really is. You just need to find, for each ##k##, one string ##s## satisfying ##D(s)=k##. I would encourage you to write down a few specific examples; find specific strings - i.e. write down strings of ##0##s and ##1##s - satisfying ##D(s)=1##, ##D(s)=-1##, ##D(s)=2##, ##D(s)=-2## ... Try to find a pattern that works - it's been suggested that the "easiest" patterns may be different for positive and negative numbers - and go with it.
I'm not sure what you mean by too general. only patterns I see is if there's more zeros then k is negative, if there's an equal amount of ones and zeros then k = 0 and if there are more ones then k is positive which is what I said in my last post.
101010 would yield k = 0
1100110 yields k =1
and 1000101 yields k = -1
1100110 yields k =1
There are some simpler strings you could try. For example, what are D(1), D(11), D(111), ...?
they'd be k =1,2,3 respectively and they contain no zeros. so there's strings that have no ones or no zeros but that's covered
if k < 0 then number of ones < number of zeros and If k > 0 then number of ones > number of zeros
seems to me the best is still to say
let s in S such that s has (k+j) ones and j zeros where k,j in Z
now D(s) = (k+j) - j = k
Okay. So the definition of onto is: A function ##f : A \rightarrow B## is said to be onto if, for every ## b \in B## there is an ##a \in A## such that ##f(a) = b##.
Your job is then to take an arbitrary ##k \in \mathbb{Z}## which you fix and then find a string ##s## in ##S## such that ##D(s) = k##. Since your ##k## was chosen arbitrarily, it must then hold for all ##k## in ##\mathbb{Z}##. Given a fixed ##k## you only need to find ONE string. When you introduce ##j## you are introducing a whole family of strings, which is not necessary and thus looks bad.
You also forgot to consider the cases when either ##(j + k) ## or ##j## is negative.
okay I see the issue with j.
one string could be
11111 and D(11111)=5, 5 in Z
like that? almost like finding a counterexample
one string could be
No. You need to treat all ##k## at the same time. I will try to outline it for you.
"We take any ##k \in \mathbb{Z}##. Now consider the string ##s = ? ## in ##S##. Then ##D(s) = k##."
I suggested that it would be easier to find strings if we consider the cases ##k>0##, ##k<0## and ##k= 0## separately. Then the proof could look something like:
"Take any ##k## in ##\mathbb{Z}##. Then exactly one of ##k>0##, ##k<0## and ##k=0## is true. We will consider each case separately.
First, if ##k=0##, we take the string ##s = 10.## Then ##D(s) = 0 = k##.
Second, if ##k>0##, we take the string ##s = ...##
Third, if ##k < 0##, ..."
Can you fill in the dots?
Likes 1 person
Actually, let me give a simple example where I prove that a function is onto.
Consider the function ##g : \mathbb{Z} \rightarrow \mathbb{Z}## given by ##g(k) = k + 1.## Show that ##g## is onto.
Solution: Take any ## k \in \mathbb{Z}## (the codomain). We need to find an element ##l## in ##\mathbb{Z}## (the domain) such that ##g(l) = k##. Therefore, take ##l = k - 1##. Then ##g(l) = g(k - 1) = k - 1 + 1 = k##.
Look at the definition of onto that I wrote in an above post. Can you see why the argument I just gave shows that ##g## is onto?
Well, to prove surjectivity, you only need one example for each ##k##. Seems to me the simplest string that works for a given positive ##k## is simply the string containing ##k## ones and no zeros. What about for negative ##k##?
for a negative k, it would be a string containing all zeros and no ones,
for a k = 0, the string would contain equal number of ones and zeros
  • · Replies 0 ·
