Dark matter and spacetime metric
In summary, the galactic rotation curves could be attributed to a deviation of the metric of spacetime from the ideal Schwarzschild metric.
Angelika10
37
I'm wondering if the galactic rotation curves could be attributed to a deviation of the metric of spacetime from the ideal Schwarzschild metric.
The Schwarzschild-metric is a well tested good approximation for the regions near the central mass - but at the outer space, far away from the central mass, we only assume that the curvature of spacetime approximates to zero (the curvature approximates to zero, the spacetime approximates to the Minkowski-Space). Could a deviating curvature of spacetime in the "far away field" lead to an accelaration in comparison to the (assumed) vanishing curvature?
It's like the difference whether we 1. assume the spacetime to be Minkowskian without matter - just add matter and curvature to the empty flat space or whether we 2. assume the spacetime itself is curved to vanish in the outer regions.
A "vanishing" spacetime (3 space dimensions approximating zero (not 1 = Minkowski, as in the standard model) and time accelerating to infinite) would build a curvature which would lead to an accelaration in comparison to the "Minkowskian outer space" which we assume in the standard model.
If one uses the rotation curves of the outer stars (constant velocity, independent of the distance r to the central mass) to determine the metric (standard form, spherically symmetric) the resulting metric is something like the square root of (r to the power of 3) in time and its inverse in space.
How about that idea?
Have you seen something like that anywhere in the literature?
Astronomy news on Phys.org
This sounds an awfully lot like a personal theory, but the answer is "no". This would lead to a modification of Newton as a function of position, and it is known that this does not match the data. If you go down this path, it needs to be a function of acceleration.
Likes ohwilleke
Thank you, Arman777, for the article - that's exactly what I was looking for.
@Vanadium: Of course it is not independent of acceleration. And of course it leads to a modification of Newton. There's nothing wrong with a modification of Newton - General Relativity is a modification of Newton. One should only be careful to maintain Newton's law at the "solar system" point of the universe.
Farnes just tried quite successfully to explain the rotation curves by negative masses. Negative Masses or just "less space" lead to the same maths.
Let's begin with spherically symmetric, general metric and v(r) = const. in the outer regions of the galaxies...
Likes Arman777
Please read my whole sentence, This would lead to a modification of Newton as a function of position, and it is known that this does not match the data.
I don't understand why you think it would lead to a modification of Newton as a function of position. If the shape of the Schwarzschild-metric is different as we believe it is, like in Vossos (the link Arman posted), than the modification of Newton would be a function of accelaration.
In the potential in Vossos, there is a point, where the Potential crosses the x-axis. This point is not dependent on position.
Likes ohwilleke
That paper is unpublished, so we don't discuss unpublished papers here. More to the point it is missing a good fraction of its equations.
Galaxies are non-relativistic. Therefore the only term that matters is the 00 term. That in turn means that two non-relativistic particles at the same point see the same curvature - or force - irrespective of their accelerations.
We can easily derive a metric by assuming a constant (independent of radius r) velocity in the outer regions of the galaxies: The outer stars gauge that metric in that point of view.
That metric can be combined with the Schwarzschild-metric of the near field to get a complete metric. It's just the "curvature-way" of MOND.
I really do not get why you complain about "function of position". Not r distinguishes, where the "new metric" crosses the x-axis - but value of the central mass.
it should read "the metric crosses y = 1" (not "the x-axis").
1. What is dark matter?
Dark matter is a type of matter that does not interact with light and cannot be directly observed. It is believed to make up about 85% of the total matter in the universe and is thought to be responsible for the gravitational effects observed in galaxies and other large-scale structures.
2. How is dark matter different from regular matter?
Regular matter is made up of atoms and subatomic particles that interact with light and can be observed through various methods. Dark matter, on the other hand, does not interact with light and can only be detected through its gravitational effects on visible matter.
3. What is the role of dark matter in the universe?
Dark matter plays a crucial role in the structure and evolution of the universe. It helps to hold galaxies and galaxy clusters together through its gravitational pull, and it also affects the expansion of the universe. Without dark matter, the universe as we know it would not exist.
4. How is dark matter related to the spacetime metric?
The spacetime metric is a mathematical representation of the fabric of space and time. Dark matter affects the spacetime metric by contributing to the overall mass and energy density of the universe. This, in turn, affects the curvature of spacetime and the motion of objects within it.
5. How do scientists study dark matter and the spacetime metric?
Scientists use a variety of methods to study dark matter and the spacetime metric, including observations of gravitational lensing, galaxy rotation curves, and the cosmic microwave background radiation. They also use computer simulations and mathematical models to better understand the behavior of dark matter and its effects on the spacetime metric.
  • Astronomy and Astrophysics
