reinhard55
- 15
- 4
Is it possible that dark matter has Planckmass and Spin two?
The discussion centers on the feasibility of dark matter candidates possessing Planck mass (approximately 10^18 GeV/c²) and spin-2 characteristics. It concludes that such candidates face significant challenges, primarily due to their inability to meet thermal freeze-out conditions necessary for stability since the Big Bang. The conversation highlights that most dark matter research focuses on candidates within the 1-1000 GeV range, as heavier candidates like primordial black holes and massive compact halo objects (MACHOs) have been largely ruled out. Additionally, the constraints on massive spin-2 bosons suggest they cannot effectively function as dark matter due to their gravitational coupling limitations and the lack of observational evidence supporting their existence.
PREREQUISITESAstronomers, theoretical physicists, and cosmologists interested in dark matter research and the implications of particle physics on cosmological models.
This is partially due to experimental constraints. Many dark matter detectors have a flat efficiency above ~100 GeV: They are equally likely to see a 1000 GeV particle as they are to see a 100 GeV particle. But their density is different: We know the mass density of dark matter, so we can calculate the density in terms of particles. The more massive the particles are the lower their density, which makes it less likely that one of them interacts in the detector. I'm sure you can write down models with 1010 GeV WIMP particles, but we wouldn't expect any of them to hit atoms in our detectors so we can't test these models.ohwilleke said:Most of the focus in dark matter research has been on candidates in the 1-1000 GeV range (called WIMPs) or less (often much less for warm dark matter, sterile neutrino and axion-like particle candidates).
ohwilleke said:The dark matter hypothesis in cosmology, and for a variety of other purposes, requires that the aggregate dark matter mass in the universe be roughly constant from shortly after the Big Bang until the present, implying either (1) a basically stable dark matter candidate, in which case it needs to fit thermal freeze out conditions,
What rules out stable dark matter that acquired mean energy well different from light matter by processes operating early in Big Bang?ohwilleke said:Thermal freeze out models of dark matter give rise to a relationship between dark matter particle mass and dark matter particle mean velocity.
We can constrain the range of dark matter particle mean velocity from visible matter dynamics much more tightly than we can constrain dark matter mass directly. If the mean velocity is too high, you get "hot dark matter" which is ruled out, because the universe is too clumpy with too much structure for that. If dark matter particles have a mean velocity that is too low, i.e. it is too cold, in contrast, you get too much structure at the sub-galaxy scale that is not observed (e.g. lots of satellite galaxies and well defined sub-halos within galaxies).
The amount of structure that we see in the universe is consistent, crudely, with the amount of structure that we would expect from a thermal freeze out dark matter candidate with a mass in the range from about 1 keV to about 1 TeV (i.e. 1000 GeV), and tends to favor the low end of that range. So, a massive spin-2 boson as a dark matter candidate can't be a thermal freeze out candidate, since it is 10^15 times too cold.
So, any Planck mass dark matter candidate needs to be one that is not a thermal freeze out particle that is stable at all times since shortly after the Big Bang, and instead must be a particle that acquires a much higher mean velocity than one would expect from thermal freeze out due to some process that continuously creates and destroys it in a equilibrium process.
I am thinking about SU(5) Bosons.Drakkith said:Is there a reason that it should?
snorkack said:What rules out stable dark matter that acquired mean energy well different from light matter by processes operating early in Big Bang?
snorkack said:The thing is, we have no lower bounds for present for any dark matter-light matter interactions. Only upper bounds. And then we have lower bounds for dark matter self-interaction, from halo shapes - but this is a lower bound on elastic scattering, not annihilation. There are searches for dark matter that annihilates into light matter, but this is only because such could be found, while dark matter that cannot so annihilate cannot be so found.
If dark matter interaction with light matter is arbitrarily weak now, it could have been stronger but still arbitrarily weak during nucleosynthesis.
Their findings – due to be published in Physical Letters B in March - radically narrow the range of potential masses for Dark Matter particles, and help to focus the search for future Dark Matter-hunters. The University of Sussex researchers used the established fact that gravity acts on Dark Matter just as it acts on the visible universe to work out the lower and upper limits of Dark Matter’s mass. The results show that Dark Matter cannot be either ‘ultra-light’ or ‘super-heavy’, as some have theorised, unless an as-yet undiscovered force also acts upon it. The team used the assumption that the only force acting on Dark Matter is gravity, and calculated that Dark Matter particles must have a mass between 10^-3 eV and 10^7 eV. That’s a much tighter range than the 10-^24 eV - 10^19 GeV spectrum which is generally theorised.
In this letter, we show that quantum gravity leads to lower and upper bounds on the masses of dark matter candidates. These bounds depend on the spins of the dark matter candidates and the nature of interactions in the dark matter sector. For example, for singlet scalar dark matter, we find a mass range 10^−3 eV≲mϕ≲10^7 eV. The lower bound comes from limits on fifth force type interactions and the upper bound from the lifetime of the dark matter candidate.
In general, quantum gravitational effects will lead to a decay of any dark matter candidate that is not protected by Lorentz invariance or a gauge symmetry from decaying. Furthermore, gravity is universal, it will thus couple to all forms of matter and it will create portals between the Standard Model and any hidden sector. While these decays will be suppressed by powers of the Planck mass, they will still lead to an upper bound on dark matter particles given the large age of our universe. Furthermore, if the dark matter particles are light, the same quantum gravitational effects will lead to fifth force type interactions and these interactions are bounded by limits coming from the Eöt-Wash experiment. Finally, there is a well known lower bound coming from quantum mechanics and more specifically the spin-statistics theorem which applies to fermionic dark matter candidate. This last bound depends on the dark matter profile.
Putting all these bounds together, we obtain tight mass ranges for scalar, pseudo-scalar, spin 1/2 and spin 2 dark matter particles which are gauge singlets. These bounds can be relaxed if the fields describing these particles are gauged, we however note that there are fairly tight constraints on the strength of the interactions in the dark matter sector. Finally, we argue that spin-1 vector dark matter particles are less constrained by quantum gravity, because of the chiral nature of the fermions in the Standard Model.
That's clearly not general enough to say everything else is ruled out.The team used the assumption that the only force acting on Dark Matter is gravity
Time to close this thread then.reinhard55 said:I don't need more discussion about it.I only wanted to know if there are ad hoc arguments against it.
