DC doesn't cause electromagnetism?
The discussion clarifies that direct current (DC) does indeed produce a magnetic field, contradicting a teacher's assertion that it does not cause electromagnetism. While DC does not create varying magnetic fields necessary for electromagnetic waves, it generates a static magnetic field around a conductor. Key concepts include the distinction between magnetostatics and electromagnetics, the role of pulsating DC in transformers, and the historical context of electromagnetism as discovered by Hans Christian Oersted.
  • Understanding of basic electrical concepts, including current and magnetic fields.
  • Familiarity with magnetostatics and electromagnetics.
  • Knowledge of transformers and their operation with DC and pulsating DC.
  • Awareness of historical experiments related to electromagnetism, specifically Oersted's findings.
  • Study the principles of magnetostatics and how they apply to DC circuits.
  • Learn about the operation of transformers with pulsating DC.
  • Investigate the historical experiments of Hans Christian Oersted and their implications for electromagnetism.
  • Explore practical applications of electromagnetism in devices like electromagnets and relays.
This discussion is beneficial for physics students, electrical engineers, and educators seeking to clarify misconceptions about DC and electromagnetism.
PrincePhoenix
DC doesn't cause electromagnetism? That is what our teacher says. Can anyone explain why it doesn't? As far I remember I made an electromagnet from a nail by passing current through it from a battery cell about 6 years ago.
Electromagnetics deals with time-varying electromagnetic waves which cannot arise due to DC sources. These are waves composed of oscillating electric and magnetic fields. The limit of electromagnetics when we go to DC is the electrostatic and magnetostatic theories. Magnetostatics certainly provides for a DC current to produce a magnetic field. Perhaps you misunderstood or your teacher mispoke.
Any charge creates an electromagnetic field, let alone current in which the field has both electric and magnetic components.
DC doesn't cause a varying magnetic field, which is required for certain electromagnetic components, eg. transformers.
I think what your teacher meant is that DC running through a straigh piece of wire will not produce a magnetic field although I'm not sure about that either. If you wrap a wire around a nail several times and run DC through the wire you will get a magnetic field though. It has to be an iron nail, no brass or steel.
Methinks PrincePhoenix should ask his teacher about that. I'm not very good at mind-reading, especially when I've never even met the person whose mind I'm trying to read. :wink:
He just says that DC doesn't work. And I might be doing something else in my "nail electromagnet" that I don't understand.
But for what purpose? Your phrase "cause electromagnetism" is unclear.
These are the generalizations about electric charge:
1. Any charged particle, moving or not, just because it exists, causes an electric field.
2. If the charged particle is also moving, including the case of any current in any wire, constant or not, straight or curved, then, in addition to producing an electric field, it also produces a magnetic field.
3. If that current keeps varying, in either magnitude or direction, then it also produces electromagnetic *waves*, which transmit energy.
No, a constant DC current does produce a magnetic field, period. Besides the Hyperphysics link that I posted, I've also done lab experiments which use an ordinary magnetic compass to study the magnetic field produced by a straight wire that carries a few amps of DC current.
The ampere is defined with respect to the magnetic fields around two parallel straight wires each carrying a direct current.Also, if my history is correct H C Oersted discovered electromagnetism by passing a direct current through a straight wire.You need to speak to your teacher to get clarification.
  • · Replies 27 ·
  • · Replies 17 ·
