DC source rather than a clamper circuit?
  • Context: Engineering
  • Thread starter Thread starter Sami1999
    Circuit Dc Source
6 replies · 3K views
Sami1999
Why is it preferred to use a clipper circuit rather than a DC source to shift an AC source upwards on a voltage-time graph?
No relevant equations
Why is it preferred to use a clamper circuit rather than a DC source to shift an AC source upwards on a voltage-time graph?Both require a battery(DC source) so isn't it cheaper than having to use some extra elements like capacitors and diodes?
Can you provide an image of the proposed clamper circuit?
You can see that the circuit automatically adjusts its DC offset to follow the level of the signal.
I mean why not just place a battery in series with the source?
Shouldn't it have the same effect in the outcome.
You may not have access to the signal source. A battery would add a fixed DC offset, whereas the clamping arrangement adjusts for varying signal levels so the offset is just enough so the offset signal doesn't go negative.
Like @NascentOxygen said... and you would have to replace the battery on occasion. :oldwink:
