De Moivre-Laplace theorem help
  • Thread starter Thread starter 2sin54
    Theorem
The discussion centers on calculating the probability that more voters for party B than party A will be selected from a random sample of 20,000 voters, given that 5,500,000 out of 10,000,000 total voters support party A. Using the de Moivre-Laplace theorem, the probability is expressed as P = Θ(λ2) - Θ(λ1), with λ1 calculated to be approximately 14.23. The resulting probability is extremely small, approximately 0.2999 × 10-45, indicating that such an outcome is highly unlikely. The discussion highlights the use of normal approximation techniques for large sample sizes in probability theory.
  • Understanding of the de Moivre-Laplace theorem
  • Familiarity with probability distributions, specifically normal distribution
  • Basic knowledge of statistical notation and calculations
  • Experience with asymptotic analysis in probability theory
  • Study the Central Limit Theorem and its applications in probability
  • Learn about normal approximation techniques for binomial distributions
  • Explore advanced statistical methods for calculating probabilities in large samples
  • Investigate the implications of extreme values in probability distributions
Students and professionals in statistics, data science, and mathematics who are interested in probability theory, particularly those dealing with large sample sizes and normal approximations.
2sin54
There are 10 000 000 people who are going to vote. 5 500 000 will vote for the party A, the rest will vote for the party B.
20 000 voters are randomly chosen. What is the probability that there will be more party B voters than there will be party A voters (sorry for poor translation).
2. The attempt at a solution
P(party A voter) = 0.55
P(party B voter) = 0.45
There have to be at least 10 001 party B voters for the condition to be satisfied. This number can range from 10 001 to 20 000. Then, according to de Moivre-Laplace theorem the probability which I need to find:
P = Θ(λ2) - Θ(λ1) ,
where λ1 = (10 001 - 20 000*0.45)/√(20 000*0.45*(1-0.45))
Unfortunately, λ1 ≈ 14.23. λ2 is even bigger. Both, when put under the Θ function asymptotically approximate to 1. Do I have to use a different approach here?
You should expect the probability to be extremely small. The probability distribution for the number of B voters is approximately normal with mean ##9000## and standard deviation ##\sigma = \sqrt{npq} \approx 70.4##. The probability of exceeding ##3\sigma## above the mean is already only about one in a thousand, and you are looking at the probability that it exceeds around ##14\sigma## above the mean. So I don't necessarily think you are doing anything wrong, but the answer is going to be tiny.
Thank you for the clarification. I guess it is just a bit counter-intuitive to me.
To get some intuition, consider flipping a coin 20000 times. Surely if the coin is fair (##p = q = 0.5##), it should be extremely unlikely that you would see, say, 11000 heads or more. Probably the only surprise is exactly how tiny the probability is, but you would expect it to be quite small. Your problem is similar, but with slightly different ##p## and ##q##.
P = Θ(λ2) - Θ(λ1) ,
If you want an actual numerical approximation, use the fact that for the standard normal pdf
\phi(z) = \frac{1}{\sqrt{2 \pi}} e^{-z^2/2}
we have, for large ##z > 0##:
\Phi_{>}(z) \equiv \int_{z}^{\infty} \phi(t) \, dt \sim \frac{1}{z} \phi(z).
This follows from integration by parts: in ##\int \phi(t) \, dt,## take ##u = 1/t,
: dv = t \phi(t) \, dt = -d (\phi(t))##. Thus
\int_z^{\infty} \phi(t) \, dt = \phi(z)/z - \int_z^{\infty} \frac{1}{t^2} \phi(t) \, dt,
and for large ##z > 0## we can drop the second term (its magnitude is ##< \phi(z)/z^2##). If you want better accuracy, get another term using integration by parts again, etc.
Anyway, for ##z = 14.23## we have ##\Phi_{>}(z) \approx 0.2999 \times 10^{-45}##.
