Debugging Strange Fortran Code: A Simple Delta Function
  • Context: Fortran
  • Thread starter Thread starter phynewb
    Code Fortran Strange
5 replies · 6K views
phynewb
Hi guys,
I just wrote a simple code for delta function and print it out. Here it is.
Code:
      program main
        implicit none
        integer i
        real*8 del
        real*8,parameter:: ep=1D-2
        real*8,parameter:: pi=3.1415926
        do i=-10,10,1
        write(*,*) i,del(real(i))  ! use function
        enddo
        do i=-10,10,1
        write(*,*) i,(1.0/pi*ep/((real(i))**2+ep**2)) ! no use function
        enddo
        end
      function del(x)
      implicit none
      real*8 del
      real*8 x
      real*8,parameter::ep=1D-2
      del=(1.0/pi*ep/(x**2+ep**2))
      return
      end
It turns out to be quite wrong by using function del. I cannot figure out what's wrong with the function because the expression is the same. Can you tell me how to debug the function? Thanks!
phynewb said:
Hi guys,
Code:
      program main
        implicit none
        integer i
        real*8 del
        do i=-10,10,1
        enddo
        do i=-10,10,1
        enddo
        end
      function del(x)
      implicit none
      real*8 del
      real*8 x
      return
      end
What output do your two loops produce?
It shows
-10 31.830990148286446
-9 4.42379935910539249E-054
-8 3.96072696157977595E-306
-7 31.830990148286446
-6 4.42379936653263965E-054
-5 0.0000000000000000
-4 31.830990148286446
-3 4.42379937841623373E-054
-2 0.0000000000000000
-1 31.830990148286446
0 4.42380394766179441E-054
2 4.42380242655975552E-054
3 31.830990148286446
4 4.42380241467614869E-054
5 31.830990148286446
6 4.42380240873434528E-054
8 4.42380240279254245E-054
9 31.830990148286446
10 4.42380239982164045E-054
-10 3.18309583173281331E-005
-9 3.92974701861929112E-005
-8 4.97358443944407051E-005
-7 6.49610718106421125E-005
-6 8.84191714697638248E-005
-5 1.27323451299340604E-004
-4 1.98942445036508832E-004
-3 3.53673738606087140E-004
-2 7.95754859835665312E-004
-1 3.18278073675496917E-003
10 3.18309583173281331E-005The upper part is from the function and the lower part is calculated without function. It shall look like sharp gaussian distribution around 0 instead of random distribution.
I'm pretty sure this line is causing the problem:
Code:
In the call to your del function, you are converting an integer value, i, to a four-byte real (a single-precision floating point value), but the function is expecting an eight-byte real (a double-precision floating point value).
I think this will fix the problem:
Code:
write(*,*) i,del(dble(i))  ! use function
Here's a link to a page with more information - http://www.liv.ac.uk/HPC/HTMLF90Course/HTMLF90CourseNotesnode114.html .
Code:
Code:
Thanks Mark44. It really works! I am always troubled by this accuracy stuff...
Thank you a lot :p
It's more about the size, in bytes, of the variables you're using. For floating point variables, the choices are real*4 (single precision - 4 bytes) and real*8 (double precision - 8 bytes). real() converts whatever to a 4-byte floating point value and dble() converts whatever to an 8-byte floating point value.
Make sure that what you pass to a function is what it is expecting - otherwise you'll have problems.
