Decarbonizing an Engine with Water: Myth or Fact?
  • Context: Automotive
  • Thread starter Thread starter zoobyshoe
    Engine Water
The discussion centers on the efficacy of using water injection to decarbonize car engines, a technique that involves introducing water into the intake of a running engine. Proponents argue that water turns to steam upon contact with hot engine components, dislodging carbon deposits. However, skepticism remains regarding the effectiveness of this method, with experts noting that while water can clean certain areas, it does not address carbon buildup in critical locations such as intake valves and EGR passages. Historical references to steam injection in vehicles and its potential benefits are also examined, highlighting the need for further investigation into this practice.
  • Understanding of internal combustion engine mechanics
  • Familiarity with water injection systems
  • Knowledge of carbon buildup and its effects on engine performance
  • Awareness of historical practices in engine maintenance
  • Research the principles of water injection in internal combustion engines
  • Explore the effects of carbon buildup on engine performance and efficiency
  • Investigate modern decarbonization techniques and their effectiveness
  • Learn about the historical use of steam injection in automotive applications
Automotive engineers, mechanics, DIY car enthusiasts, and anyone interested in engine maintenance and performance optimization.
  • #61
In a running engine surface temperature change (and especially bulk temperature) isn't that great. From what I know it's the mechanics of steam expansion that does the trick.
  • #62
We are starting to see engine damage from carbon breaking loose and sticking in the ring lands.
Can scuff cylinder walls.
There are some good chemicals out there to dissolve the carbon gradually instead of blasting it off.
  • #63
If the engine is disassembled so you can clean up the mess afterwards, Carbon tetraChloride, also called Tetrachloromethane, (CCl4) is a solvent for Carbon. The big problem is that CCl4 causes Cancer.
  • #64
Yeah, I'm not sure we should suggest that for anybody who isn't a chemist with access to an exhaust fume hood...
  • #65
The Internet can sure sound evil. This thread made me curious as to whether carbon tet was still sold. I searched and the first hit at the top of the page was "Black Friday Specials on Carbon Tetrachloride" o_O
  • #66
At toyota, a recall campaign has us reading the tops of the pistons for numbers to determine if they are part of the lot of "bad pistons" put into camry 4 cylinder engines.
We use a BG product that smells identical to the product I pictured earlier in the thread.
The problem is that almost nobody at the dealerships understands basic physics and they end up having trouble getting the pistons clean enough.
I'm sure some cars are being damaged as well.
  • #67
Ive recently lost two weed whacker engines for just that reason. In both cases there was a bit of carbon "missing" and a score line down the bore just below it. Fortunately they weren't expensive machines.
  • #68
Interesting observation.
Do you use regular pump gas with ethanol or ethanol free? E10 gas will absorb minor amounts of moisture , and will eventually separate into two or three distinct layers - water , alcohol and gasoline... That can be problematic if fuel is stored more than a very few months.
https://ethanolrfa.org/wp-content/uploads/2016/09/Evaluation-of-Water-Uptake-by-Ethanol-RFA-09-16.pdf
old jim
  • #69
I try and buy ethanol free but it's not available locally so it takes planning to get some. I think I just didn't realize how much carbon was building up. Now I know I'll keep an eye on it.
  • #70
So I’d just like to let everyone know .. my car had a lot of flat spots and sometimes wouldn’t Rev over 3k rpm , it was starting to annoy me so I started changing all sorts of parts and nothing worked... till I tried the water into the air intake ... I got a spray bottle boiled the kettle let it cool down to normal temp again to make sure all bad deposits were gone , then I got my wife to hold the revs at 2.5-3k rpm , I sprayed the water little by little as when the engine revs wanted to drop I stopped let it pick back up and repeated this over and over , I left the car running on idle while I went and filled the spray bottle back up for another 5l to go in.. so 10l of water bit by bit for over half an hour let the engine run idle for 5 mins after I had done it, took her out for a spin and what a difference it had made ! No more flat spots no more lag just like it was because the problems start , so am wondering if carbon had built up around the swirl flaps or intake manifold itself and the water has got rid of it , 100% worked thought I would share my experience
