- 11,943
hi guys
Today I would like to show the advantages of stacking a set of exposures over just a single shot
There are various ways to stack individual exposures. A number of programs are available ranging
from free to quite expensive ... several 100 US$
free = DSS - Deep Sky Stacker
http://deepskystacker.free.fr/english/download.htm
Photoshop CC = PS and LR, (Lightroom) CC come as a subscription these days and quite affordable
So not only do you get stacking features in PS, you also have very powerful editing software
a little more expensive
= Nebulosity
http://www.stark-labs.com/nebulosity.html
most expensive = Pixinsight around US$250
https://pixinsight.com/
Both Pixinsight and Nebulosity have reasonably steep learning curves
I have dabbled with both and in the end gone back to Deep Sky Stacker
I have done a couple of stacks in PS, They were sort of OK
The trick with all the software is learning the art of stretching the RGB colour curves to bring out all the details. Something I am still learning
Lets take a practical example and see the difference between stacking and a single image.
One of the major purposes of doing this is to improve the signal to noise ratio. The noise is
primarily sensor thermal noise that starts to come through because there isn't enough signal noise to overcome it because we are imaging in very low light and usually high ISO settings > 1000.
Because noise is random in its appearance and location in the exposure, but the signal -- the stars nebula etc isn't. The signal level is compounded and improved where the noise tends to cancel out.
This first image is a single 30 sec exposure with a 400mm lens at f5.6 and ISO 3200
The camera is a Canon 700D that I have modded by removing one of the filter elements
that limits IR/UV and colour range ... it improves the sensitivity to the red end of the spectrum
the 2 main objects are ... to the left M20 - the Trifid Nebula and to the right M8 - the Lagoon Nebula
You can see there is a bit of a pinkish hue to the image as a result of the extra red sensitivity
now here is 6 separate exposures ( all same settings) taken one after the other and stacked in DSS
The result is glaringly obvious. I have been able to keep the red hue under control. Have been able to
achieve a much better contrast between the nebulae, stars and the dark background. Also, if you look closely, you can see a definite loss of the fuzzy noise across the whole image ( the noise).
The overall result is much better detail in the imageThere is some initial comments
I will address to more stacking details in another post in this thread
Other questions and comments are welcome
cheers
Dave
cheers
Dave
