Undergrad Define the double factorial as being a continous, non-hybrid function
The double factorial, denoted as n!, is defined for positive integers by the product of decreasing even or odd integers, depending on whether n is even or odd. The discussion explores extending the double factorial to real values over the domain [-1, ∞), noting that single interpolation is not feasible due to discontinuities in derivatives at n=1. The gamma function is highlighted as a potential tool for this extension, with various formulas presented, including the duplication formula. A specific function, f(z) = 2^{(1+2z-\cos(\pi z))/4}π^{(\cos(\pi z)-1)/4}Γ(z/2+1), is proposed as a solution for odd integers and even integers. The conversation concludes with a curiosity about defining a similar function for the triple factorial.
Saracen Rue
TL;DR
Define ##x!!## as being a continuous, non-hybrid function over the domain of ##[-1, \infty)##
The double factorial, ##n!## (not to be confused with ##(n!)!##), can be defined for positive integer values like so:
$$n!=n(n−2)(n−4)(n−6)...(n-a)$$
Where ##(n−a)=1## if ##n## is odd or ##(n−a)=2## if ##n## is even. Additionally, the definition of the double factorial extends such that ##(-1)!=0!=1##
I'm curious as to if it would be possible to definite a function which not only accurately evaluates all integer values for ##n!##, ##n \geq -1##, but also allows you to calculate the value of any real value of ##n## over the domain ##[-1, \infty)##
Will be a discontinuity in second and higher derivatives at n=1. Therefore, single (not piece-wise) interpolation is not possible.
You can also continuously extend a function defined on a discrete set, but here's a concrete approach. I assume you're familiar with the gamma function ##\Gamma(z)=\int_0^{\infty} x^{z-1}e^{-x}dx## which satisfies ##\Gamma(n)=(n-1)!## when ##n## is a nonnegative integer.
There is the duplication formula ##\Gamma(z)\Gamma(z+1/2)=2^{1-2z}\sqrt{\pi} \ \Gamma(2z)##. When ##z=n## is a non-negative integer, this gives
##\Gamma(n+1/2)=\sqrt{\pi} \ 2^{1-2n}\frac{(2n-1)!}{(n-1)!}=\sqrt{\pi} \ 2^{-n} \frac{(2n-1)!}{2^{n-1}(n-1)!}=\sqrt{\pi} \ 2^{-n} (2n-1)!##
Rearranging, we find that the function ##\frac{1}{\sqrt{\pi}}2^{(1+z)/2}\Gamma(z/2+1)## is equal to ##z!## when ##z## is an odd (positive) integer. As far as I can tell, this is the standard analytic continuation of ##(2n-1)!##. Unfortunately, this formula is false when ##z## is even.
I found a stackexchange answer (https://math.stackexchange.com/ques...ion-of-factorial-be-done-for-double-factorial)
which gives the function ##2^{(1+2z-\cos(\pi z))/4}\pi^{(\cos(\pi z)-1)/4}\Gamma(z/2+1).## When ##z## is odd, this is just the function I gave above. When ##z=2n## is even, it gives ##2^nn!=(2n)!##. I don't think this is standard though.
Likes Saracen Rue
For even ##z## one could use ##(2n)!=2^nn!##. A similar easy function is ##(2n-1)!=\dfrac{(2n)!}{2^nn!} ##. That leaves us with the problem to find one function for both cases, in which case we could simply substitute the gamma function.
Likes Saracen Rue and dextercioby
Thank you, a function like ##f(z)=2^{(1+2z-\cos(\pi z))/4}\pi^{(\cos(\pi z)-1)/4}\Gamma(z/2+1)## is exactly what I was looking for. I wonder if it would be able to define a similar such function for the tripple factorial.
  • · Replies 24 ·
  • · Replies 17 ·
