Can every atom be transformed into a noble gas?
  • Thread starter Thread starter CGandC
    Noble gases
The discussion centers around the concept of noble gases and whether every atom can be transformed into a noble gas configuration, focusing on definitions, properties, and the implications of such transformations.
  • Conceptual clarification, Debate/contested
  • One participant defines a noble gas as an atom with a completely filled valence shell and questions if any arbitrary atom can achieve this state.
  • Another participant argues that while most atoms can reach a noble gas configuration, they do not become a different element in the process, suggesting that elemental identity is maintained regardless of electron configuration.
  • A third participant notes that noble gases are typically in their ground state but acknowledges that some noble gases can form compounds, indicating a complexity in their behavior that may challenge the traditional definition.
Participants express differing views on the implications of achieving a noble gas configuration, with some agreeing on the possibility of reaching such states while others emphasize the distinction between elemental identity and electron configuration.
The discussion does not resolve the implications of noble gas configurations on elemental properties, nor does it clarify the conditions under which atoms might achieve such configurations.
CGandC
TL;DR
Is noble gas defined as an atom that can be brought to have a valence shell completely filled with electrons? ( even if the atom, as we are observing it now doesn't have its valence shell completely filled? )
'noble gas' is defined as an atom with its valence shell completely filled to its capacity with electrons.
Assuming I take an arbitrary atom ( with its valence shell not necessarily completely filled yet ) and assuming I am either adding electrons to it or removing electrons from it or doing nothing, and assuming it is possible to reach some state in which the atom has a highest energy level ( out of all occupied shells ) completely filled with electrons to its fullest capacity - is such an atom defined as a noble gas?
If yes, can every atom be made into a noble gas ( at-least for a short period of time )? ( i.e. an atom that can be reached into a configuration in which some shell will be a valence shell and will be completely filled with electrons )
Chemistry news on Phys.org
You are mixing two things. Noble gas is an element with a completely filled valence shell. Yes, you can reach the noble gas configuration for most atoms. It won't make them other element they already are (what is the basic property shared by all atoms of any given element?).
Noble gases, as identified in the Periodic Table etc., are considered to be in their ground state. On the other hand, the definition is of some historical value, for we know now that some of the so-called noble gases can participate in chemical compounds; for instance, xenon.
Thanks for the answers, it cleared up what I've wanted to know :)
46K
