Convergence of the Sequence √n(√(n+1)-√n) to 1/2
The limit of the sequence defined by the expression √n(√(n+1) - √n converges to 1/2 as n approaches infinity. The key steps involve simplifying the expression to √n / (√(n+1) + √n) and demonstrating that it is bounded above by 1/2. Additionally, establishing a lower bound of 0 is necessary to confirm convergence using the definition of limits. The discussion emphasizes the importance of limit arithmetic and the Archimedean principle in proving convergence.
  • Understanding of limits in calculus
  • Familiarity with the properties of square roots
  • Knowledge of the Archimedean principle
  • Basic algebraic manipulation skills
  • Study the properties of limits and continuity in calculus
  • Learn about the Archimedean property and its applications in analysis
  • Explore techniques for proving convergence of sequences
  • Review algebraic manipulation techniques involving square roots
Students studying calculus, particularly those focusing on sequences and limits, as well as educators looking for examples of convergence proofs.
Mr Davis 97
Show that ##\displaystyle \lim_{n\to \infty} \sqrt{n}(\sqrt{n+1}-\sqrt{n}) = \frac{1}{2}##
We see that ##\displaystyle \sqrt{n}(\sqrt{n+1}-\sqrt{n}) - \frac{1}{2} = \frac{\sqrt{n}}{\sqrt{n+1}+\sqrt{n}} - \frac{1}{2} < \frac{\sqrt{n}}{2\sqrt{n}} - \frac{1}{2} = \frac{1}{2} - \frac{1}{2} = 0##. But I don't think this can be right... What am I doing wrong?
Mr Davis 97 said:
##\frac{\sqrt{n}}{\sqrt{n+1}+\sqrt{n}}##
Try dividing the top and bottom of this fraction by something, then take the limit as ##n\rightarrow \infty##.
Nothing, except that the step of subtracting ##\dfrac{1}{2}## is unnecessary. You can directly go to
\sqrt{n}(\sqrt{n+1}-\sqrt{n})=\dfrac{\sqrt{n}(\sqrt{n+1}-\sqrt{n})(\sqrt{n+1}+\sqrt{n})}{\sqrt{n+1}+\sqrt{n}}=\dfrac{\sqrt{n}}{\sqrt{n+1}+\sqrt{n}}< \dfrac{\sqrt{n}}{2\sqrt{n}}=\dfrac{1}{2}
Now the limit is definitely smaller than a half. What a bout the lower bound?
Well a lower bound would be 0. But I am trying to do this using the definition of convergence. I'm doing the scratchwork to find the ##N## and can associate with every ##\epsilon##. Like normally in the end we get like a difference between the sequence and the limit as ##1/n < \epsilon##, and so we select ##N## s.t. ##1/N < \epsilon##, and by the archimdedian principle this exists. However, in this case I just get that the difference is 0...
You need to prove something like ##\frac{1}{2}-\frac{c}{n} \leq a_n## so that the gap is closing down with increasing ##n##.
However, the easier method is to follow @Eclair_de_XII 's suggestion and simply cancel out ##\sqrt{n}## and then use the rules given for limit arithmetic. My question only refers to the way you have chosen, in which case you need a lower bound.
  • · Replies 17 ·
