Definition of Order of Operations
The order of operations in mathematics, defined by PEMDAS, was established for convenience in working with polynomials and to avoid ambiguity in calculations. This hierarchy allows for a consistent approach to computation, where exponents are evaluated before addition and subtraction. While the order is somewhat arbitrary, it facilitates a clear notation that avoids the need for excessive parentheses, as seen in some programming languages like Lisp. The discussion highlights that this structure aids in preserving a logical progression in mathematical operations. Ultimately, the order of operations serves as a shorthand that simplifies mathematical expressions and ensures uniformity in results.
V0ODO0CH1LD
I realize now that I took something for granted when I first learned it god knows when.. So I though of starting a discussion as to why were the order of operations defined the way they were? I mean, is there some kind of natural explanation as to why we should compute exponents first and additions and subtractions last? Or is it one of those "right-hand rule" dilemmas where we are just trying to avoid one question having multiple answers?
Mathematics news on Phys.org
The order of operations was defined by mathematicians. From what I know, most likely to make writing polynomials easier.
Certainly you can define the order of operations in a variety of ways. But it makes things look unnatural.
For example
Take 5x^2 + 3x + 10 under the normal order of operations.
Now say that addition should come before muliplication.
Let's try to re-write that same polynomial.
(5x^2) + (3x) + 10
I have to add parenthesis here to get the same result.
I guess my point is that in the math we use, we made the order of operations the way it is for convenience. I think that it kind of makes sense the way it is. Without going into too much details think about how you first learned multiplication.
You were probably told that 5*4 = 5 + 5 + 5 + 5.
When you learned about exponents, you were probably told that 5^3 = 5 * 5 * 5 = (5 + 5 + 5 + 5 + 5) * 5 = 5 + 5 + 5 ... + 5
There is a nice hierarchy here that is well preserved in the way we think about them.
Order of operations is a notational shorthand that was created for convenience of working with polynomials.
In some computer languages, notably Lisp, there is not such concept. Instead, you have to parenthesize EVERY operation.
Instead of x^2 + 2x + 1, you have to write (+ (+ (pow x 2) (* 2 x)) 1). It's rather obnoxious! But, from a computer science standpoint, it is absolutely trivial to parse.
Note that the order of operations is completely arbitrary, with the exception of parentheses which have a special syntactic interpretation. If instead of PEMDAS we chose PSADME, we would instead write the above expression as
(x^2) + (2x) + 1
The PEMDAS order is such that the normal form of any polynomial (the form: a_n x^n + a_n-1 x^(n-1) + ... + a_0) is always parentheses-free.
I found a couple of interesting links.
http://mathforum.org/library/drmath/view/52582.html
and
http://jeff560.tripod.com/grouping.html
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 20 ·
  • · Replies 17 ·
