Can Energy Measurements Yield Non-Bound States in a Delta Function Potential?
The discussion centers on the energy measurements of a particle in a delta function potential, specifically questioning the implications of having only one bound state and its corresponding energy. While it is established that there is only one bound state with energy E=-mα²/2ħ², confusion arises regarding the calculation of coefficients for the initial wave function, which suggests the presence of other eigenfunctions. It is clarified that although there is only one bound state, there exists a continuum of unbound states with positive energy that can contribute to the wave function. Therefore, the initial wave function can be expressed as a combination of the bound state and scattering states. Ultimately, the conclusion is that the presence of unbound states allows for the possibility of measuring energies other than the bound state energy.
AlexChandler
A particle moves in one dimension in the delta function potential V= αδ(x). (where that is an 'alpha' ... not 'a')
An initial wave function is given
\Psi = A(a^2-x^2) for x between -a and a and Psi=0 anywhere else
What is the probability that an energy measurement will yield something other than:
E=\frac{-m\alpha^2}{2\hbar^2}
note: when we solve the delta function potential problem, we find (for E<0) that there is only one bound state, and only one allowed energy: and that is exactly the one shown above.
c_n = \int \Psi_n^* \Psi(x,0) dx
P(E_n) = abs(c_n)^2
At first I was sure that since there is only one bound state in the delta function potential problem, and only one allowed energy, that the probability of measuring another energy should be zero. But when I calculate the coefficient c1, I do not get 1, i get something like .913 and then c1 squared is about .83 which would then be the probability of measuring the bound state energy.
This is what is confusing me. If c1 is not equal to 1, then there must be some other c's with other eigenfunctions that must be combined linearly to produce the given initial wave function. But there is only one energy eigenfunction, so what are these other functions??
And if there is only one energy eigenstate, is it possible to measure an energy other than the energy of the eigenstate?
Thank you
Yes.
Are you sure?
We solved the schrodinger equation and found only one bound state with a corresponding energy. What we have done before is to expand a given state in terms of energy eigenstates, and the the constants in the summation give a probability density for the energy. But if we do such an expansion, since there is only one eigenstate, wouldn't its c value have to be 1? If not, then what other functions are we including in the linear combination?
Is the bound state the only energy eigenstate?
i don't know of any others..
The key word is bound.
If anybody has an explanation I would be happy to hear it. I have turned in the homework assignment already and decided it makes most sense to just calculate the c value for the bound state, and say
P(E \neq E_1 ) = 1 - |c_1|^2 = .17
What I am wondering about is how to express the state as a combination of eigenstates. Is it c1 times the bound state, and then plus some integral over scattering states?
Yes. From Quantum Mechanics by Robinettt
There is a discrete bound spectrum for E<0 (actually only one state), but there is a continuum of unbound states with E>0 ... The discrete and continuous states, taken together, form a complete set from which any admissible wavefunction can be constructed; the bound state solutions, by themselves, are not sufficient.
Aha! Thank you
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 29 ·
