Delta-Wye Transformations: How to Simplify Complex Circuits for Easy Analysis
2 replies · 3K views · last reply
GreatEscapist
URGENT: Delta-Wye transformations
Hello there. In my electrical fundamentals class (a 201 level class), we just barely started Delta-Wye transformations. However, the homework that is due online tonight uses full transformations...confused, I have just tried to work through this using the book. I have become stuck...
My homework is due tonight at midnight, so please help asap?
All attached
Ohm's law, and...I don't know the other ones
I have worked through most of the solution in the jpg. However, I am stuck. I know I need to find I, because if I can find I, it would be very simple to use Ohm's law in the original circuit.
I have tried to add the series and do parallel to leave
16.87 + 9.62 || 55.5 = Rd
then Rd || 36
Then you are left with a simple circuit to determine I, which I calculated to be 4.4A.
Can someone please help? haha
Sorry, didn't attach the first time
  • Four-stage circuit simplification: original resistor network with 100 V source and resistors 11, 15, 12, 31, 36, 18, 29 ohms, then a delta-to-wye step, then a reduced ladder circuit with 11, 36, 55.5, 14.67 and 9.62 ohm values, and a ground node marked 0 V.
Check the value that you obtained for Ra from the Y-Δ transformation; either it's not correct or something went wrong with combining it with the 29Ω resistor. Then continue to reduce the network until you're left with two resistances forming a voltage divider.
Circuit schematic of a 100 V source feeding a resistor network: a 11 Ω series resistor, 35 Ω, 55.5 Ω and 16.7 Ω resistors, and a 29.62 Ω resistor, with a blue loop around the lower network marked reduce to single resistance and a red note saying check calculations.
  • Circuit schematic of a 100 V source feeding a resistor network: a 11 Ω series resistor, a 16 Ω resistor on top, and 35 Ω, 55.5 Ω and 29.62 Ω resistors, with a blue loop marking the network to reduce to a single resistance.
