Density of water as a function of depth
To estimate the density of water at a depth of 5.3 km, the initial pressure is set at 1 atm, and the bulk modulus for water is given as 2.0 x 10^9 Pa. The pressure at this depth is roughly calculated to be around 530 atm, which is essential for determining the change in volume and density. The discussion highlights the challenge of finding pressure as a function of variable density, suggesting that a constant density assumption simplifies calculations. Ultimately, integrating the relevant equations can lead to a more accurate estimate of density without complicating the approach with differentials. Understanding these relationships is crucial for solving the problem effectively.
LBloom
Estimate the density of the water 5.3 km deep in the sea. (bulk modulus for water is B=2.0 *10^9
\DeltaV/V=(-1/B)*\DeltaP
dP/dY=-\rhog
I tried to use the equation:
P=Po*e^(-\rhoo/Po)*gh
But i kept getting ridiculously large answers that i don't think could possibly be true.
I said that the initial pressure was 1atm or 1.013*10^5 Pa and that initial density was 1*10^3(kg/m^3).
I know that once i get the pressure under water, I can find the change in volume divided by volume (delta V over V) and from there figure out how what the density of a theoretical block of water would be if submerged 5300 meters. Its just finding out the pressure that trips me up. Am i using the wrong constants or must i derive a different equation for pressure as a function of height?
I tried to find volume as a function of pressure, but its finding the pressure with a variable density that keeps throwing me off. I'm not sure the third equation i used is correct for this kind of problem.
as a sense check, first assume the density is constant, calculate the pressure at 5.3km (10m of water is ~1atm so will be around 530atm). now use this to estimate the density as the chaneg will probably be reasonably small... also gives you an idea of your error
now for a more accurate assumption, set up your de as follows..
\rho(V) = \frac{m}{V}
\frac{d}{dV} \rho(V) = -\frac{m}{V^2}
d \rho = -\frac{dV}{V} \rho
then from the bulk modulus
\frac{dV}{V} = -\frac{dP}{B}
d \rho= \frac{dP}{B} \rho
or
dP = B \frac{d \rho}{\rho}
then the pressure gradient with denisty you know
\frac{d}{dy} P(y) = \rho(y).g
re-arranging
dP(y) = \rho(y).g.dy
then combine the equations & integrate
thank you for your help, and i certainly will look this this over to get a better understanding of the problem, but I actually made this problem more difficult than it had to be and i don't need differentials. thanks again though
11K
