Denumerable set and surjective function
14 replies · 4K views
autre
This is the problem:
"Prove that if A is denumerable and there exists a g: A -> B that is surjective, then there exists an h: B -> A so that h is injective."
So I've started it as:
Suppose a set A is denumerable and a function f: A-> B is surjective. Since there exists a surjective function f: A-> B and A is denumerable, B is countable..."
I'm a little stuck here. Any ideas?
Try to explicitely define h. You won't need anywhere that A and B are denumerable.
Try to define h as some kind of "inverse" of g.
Try a simpler problem first, replacing the assumption "A is denumerable" with "A = N, the set of natural numbers." If you have surjection g : N --> B, you can explicitly define an injection h : B --> N in terms of g. See if you can figure that out first.
Good idea.
How about something like this:
Suppose there exists a function f: N -> B for some set B. Then, for all b in B, there exists an n in N such that f(n) = b. Define h: B-> A as the function that maps all b in B to a single n in N such that h(b) = n. Since f is surjective, there exists such a function. Since h(b') = h(b) = n iff b' =/= b, h is injective.
Am I on the right track?
Great. For each b, there might be a number of different n's you could choose. How might you explicitly choose one of those n's from amongst all the possible choices, if you had to?
This isn't quite right, perhaps a typo?
Yes.
Perhaps an n such that if f(n) = f(n') = b, n=n'?
Not a typo, just brainstorming. :redface:
How may you explicitly choose an element from a subset of the natural numbers?
You can use the axiom of choice, or a much easier method which you probably are familiar with.
The well-ordering principle?
Quick question, can I assume A = N without loss of generality?
Why wonder when you can just pick the smallest one?
You can assume A = N if you are comfortable with the proof of how it applies generally (hint: A is in bijection with N).
I'm not sure if we have gone over the theorem that states that every subset of N has a smallest element, is it related to the well-ordering principle?
So perhaps something like this:
Suppose there exists a function f: N -> B for some set B. Then, for all b[itex]\in[/itex]B, there exists an n[itex]\in[/itex]N such that f(n) = b. Define h: B-> N as the function f(b) = n' where for all b[itex]\in[/itex]B, n'[itex]\in[/itex]N' is the smallest element of some N'[itex]\subseteq[/itex]N. Thus, h is injective.
Well, it's obvious isn't it? If n is a number in a subset A of N, then one of 1,2,3,...,n is the smallest element of the set. Prove: Every subset of the natural numbers containing the number n has a smallest element, by induction on n.
There is something weird about defining h(b) = n', where n' is the smallest element of some subset N' of N. You must specify this subset, or else h is not well-defined (it can't be any arbitrary set). I suggest you define N' = f^(-1)(b) (= the set {n in N : f(n) = b}). Then you can show injectiveness.
Well, it's obvious isn't it? If n is a number in a subset A of N, then one of 1,2,3,...,n is the smallest element of the set. Prove: Every subset of natural numbers containing n has a smallest element by induction on n.
Ah, I think I have seen that before. In light of this, does the proof I provided above work?
