Denumerable set and surjective function
The discussion revolves around proving that if set A is denumerable and there exists a surjective function g: A -> B, then an injective function h: B -> A can be constructed. Participants suggest starting with a simpler case where A equals the natural numbers, allowing for explicit definitions of h based on the surjectiveness of g. The well-ordering principle is mentioned as a method to choose elements from subsets of natural numbers, emphasizing the importance of defining subsets clearly to ensure h is well-defined. Ultimately, the conversation focuses on the construction of h and ensuring its injectiveness through careful selection of elements. The proof hinges on the relationship between the elements of A and B, confirming the injective nature of h.
autre
This is the problem:
"Prove that if A is denumerable and there exists a g: A -> B that is surjective, then there exists an h: B -> A so that h is injective."
So I've started it as:
Suppose a set A is denumerable and a function f: A-> B is surjective. Since there exists a surjective function f: A-> B and A is denumerable, B is countable..."
I'm a little stuck here. Any ideas?
Any ideas?
I'm really stuck guys :frown:
Try to explicitely define h. You won't need anywhere that A and B are denumerable.
Try to define h as some kind of "inverse" of g.
Try a simpler problem first, replacing the assumption "A is denumerable" with "A = N, the set of natural numbers." If you have surjection g : N --> B, you can explicitly define an injection h : B --> N in terms of g. See if you can figure that out first.
Good idea.
How about something like this:
Suppose there exists a function f: N -> B for some set B. Then, for all b in B, there exists an n in N such that f(n) = b. Define h: B-> A as the function that maps all b in B to a single n in N such that h(b) = n. Since f is surjective, there exists such a function. Since h(b') = h(b) = n iff b' =/= b, h is injective.
Am I on the right track?
Great. For each b, there might be a number of different n's you could choose. How might you explicitly choose one of those n's from amongst all the possible choices, if you had to?
This isn't quite right, perhaps a typo?
Yes.
Perhaps an n such that if f(n) = f(n') = b, n=n'?
Not a typo, just brainstorming. :redface:
How may you explicitly choose an element from a subset of the natural numbers?
You can use the axiom of choice, or a much easier method which you probably are familiar with.
The well-ordering principle?
Quick question, can I assume A = N without loss of generality?
Why wonder when you can just pick the smallest one?
You can assume A = N if you are comfortable with the proof of how it applies generally (hint: A is in bijection with N).
I'm not sure if we have gone over the theorem that states that every subset of N has a smallest element, is it related to the well-ordering principle?
So perhaps something like this:
Suppose there exists a function f: N -> B for some set B. Then, for all b\inB, there exists an n\inN such that f(n) = b. Define h: B-> N as the function f(b) = n' where for all b\inB, n'\inN' is the smallest element of some N'\subseteqN. Thus, h is injective.
Well, it's obvious isn't it? If n is a number in a subset A of N, then one of 1,2,3,...,n is the smallest element of the set. Prove: Every subset of the natural numbers containing the number n has a smallest element, by induction on n.
There is something weird about defining h(b) = n', where n' is the smallest element of some subset N' of N. You must specify this subset, or else h is not well-defined (it can't be any arbitrary set). I suggest you define N' = f^(-1)(b) (= the set {n in N : f(n) = b}). Then you can show injectiveness.
Well, it's obvious isn't it? If n is a number in a subset A of N, then one of 1,2,3,...,n is the smallest element of the set. Prove: Every subset of natural numbers containing n has a smallest element by induction on n.
Ah, I think I have seen that before. In light of this, does the proof I provided above work?
