Depleted region in Semiconductor and leakage current
In summary, the author is discussing the behavior of thermally generated electron-hole pairs in the depletion region of a diode detector. These pairs are quickly swept out by the electric field, preventing them from building up and contributing to a noisy background current. The author also mentions that this behavior is important because it affects the device's response to photo-generated carriers.
abotiz
72
Hi,
Iam reading the book Glen F. Knoll Radiation Detection and Measurements, and Iam having a trouble understanding a certain part of the chapter about semiconductor, he writes:
Electron-hole pairs that are created within the depletion region by the passage of radiation
will be swept out of the depletion region by the electric field, and their motion constitutes
a basic electrical signal.
The thermal generation of charge carriers will continue to take place in the depletion
region, contributing a component sometimes called the generation current to the observed
leakage current. These charges are swept away typically within a few nanoseconds, however,
a time that is many orders of magnitude shorter than the time required to establish thermal
equilibrium.
Thus, the steady-state concentration of carriers is strongly reduced in the
depletion region because the removal of charges is a much faster process than their
creation.
I don't understand the sentences in bold, why does it matter how fast they are swept away? As long as they are created, and move under an electric field, they constitute an electric signal. Sure, the depletion region is depleted of mobile charge carriers and that greatly reduces the leakage current, but this second benefit of the short time they are swept away?
Iam certain that Iam missing something here. Can someone who understand this clarify this for me?
Thank you very much!
It appears that you are talking about photodiode detectors? The quote agrees with your statement that thermally generated electron-hole pairs constitute a current--specifically, a leakage current that will look like a noisy background to the photocurrent. I think the author is simply pointing out that the charges do not remain and build up in the depletion zone because they are rapidly swept away,
Likes 1 person
Thank you for your reply.
Yes, photodiode detectors.
I still don't get it. Thermally generation is a random process, it happens all the time and you could say that an equilibrium would be created, where these thermally generated carriers contribute to a current of e.g 1mA. Why is time important?
Its like saying you have a material where a radionuclide with short half life is constantly created and because the half life is so short, you do not detect this with e.g. GM tube. Of course you would. However, if the radionuclide is in a limited amount, then sure, time is important, if the radionuclide decays away then there would be no additional counts.
Please help me understand this!
It's hard for me to know what the point is from a short snippet of text. Here is my guess: You are focusing on the leakage current, but there are other effects in a diode that can be important. Charges building up in the depletion zone, or in the I region of a PIN photodiode, can change the device's effective capacitance and conductance, and could potentially alter its response to photo-generated carriers. (If the depletion zone disappears, for instance, then photo-carriers would have to diffuse to the terminals instead of being swept at the drift velocity. Many photo-carriers would recombine, hurting sensitivity. The diode response, furthermore, would be orders of magnitude slower.) The back bias that is implied in your short quote keeps the depletion zone free of thermally generated carriers, however. This is because they are generated at a slow rate but are swept away nearly instantaneously.
This description is what I remember from yo those many years ago of study...
http://en.wikipedia.org/wiki/Depletion_region
first sentence:
A depletion region forms instantaneously across a p–n junction.
due to N and P doped regions adjacent which induce an electric field. All I read into this is that thermally generated carriers move along 'promptly' and constitute part of leakage current.
Maybe your particular description is a 'warm up' for a later discussion of thermal/shot noise??
If you don't get an answer here, try 'electrical engineering'... they study this for sure.
If the thermally generated charge carriers in the depletion region persisted for a time on the order of the time required for the E field to establish thermal equilibrium(in the Gibbs sense), then the thermal noise signal would swamp out the radiation signal. The average E field amplitude would be a random function of time and the response of the system would be highly non linear.
If the thermally generated electron-hole pairs were created much faster than they are swept out, then you would not get a depletion effect. You'd have a normal thermal equilibrium electron and hole concentration and hence basically a low DC conductivity. The thermal background current would be quite large, and you would be very limited in the bias voltage you can apply.
If on the other hand the sweeping out is fast and the thermal generation slow, then you have a depleted region without any free carriers and occasionally a electron-hole pair produces a very small and short current spike. Now since even in a small and thin photodiode you still have a lot of atoms, this still happens very often and thus produces a noisy, fluctuating background current.
Likes 1 person
I don't understand the implication of the prior two posts. It would seem the thermal noise current is what it is.
It seems counter-intuitive that a slower removal of thermally generated charge carriers, that is, more mobile charge carriers in the depletion region, would increase such a current. Is that what is being implied?
Thank you for your answer. Iam beginning to understand what the author mean.
The author just made it confusing I think. He propably meant this simple statement. Like you said:
If they were to remain there would be a rising leakage current (and the response of the diode would be non-linear) rather than a constant leakage current (enabling a linear response).
Thank you, this helped me understand it a bit more.
Thank you all for the replies!
Related to Depleted region in Semiconductor and leakage current
1. What is a depleted region in a semiconductor?
A depleted region in a semiconductor is an area where there is a decrease in the concentration of free charge carriers, such as electrons or holes. This can occur when the semiconductor material is doped with impurities, causing an imbalance in the number of positively and negatively charged particles.
2. How is a depleted region created in a semiconductor?
A depleted region can be created in a semiconductor through a process called doping. This involves adding impurities, such as boron or phosphorus, to the semiconductor material. These impurities create an excess of either positively or negatively charged particles, which creates a depleted region in the semiconductor.
3. What is leakage current in a semiconductor?
Leakage current in a semiconductor refers to the flow of electric current through a depleted region. It occurs when there is an imbalance of charge carriers in the depleted region, causing them to move towards each other and create a current. This can be undesirable in electronic devices as it can result in energy loss and reduced efficiency.
4. How does the size of the depleted region affect leakage current?
The size of the depleted region can have a significant impact on leakage current in a semiconductor. A larger depleted region means there is a greater distance for the charge carriers to travel, resulting in a higher resistance and lower leakage current. Conversely, a smaller depleted region will have a lower resistance and higher leakage current.
5. What are some ways to reduce leakage current in semiconductors?
There are several techniques that can be used to reduce leakage current in semiconductors. These include optimizing the doping concentration to create a smaller depleted region, using materials with a wider bandgap, and implementing barrier layers to prevent the flow of charge carriers. Additionally, designing more efficient electronic circuits and devices can also help to reduce leakage current.
  • Atomic and Condensed Matter
9K
  • Quantum Physics
