Derivation of velocity in nth Bohr orbit
The discussion focuses on deriving the expression for the electron's speed in the nth Bohr orbit, specifically addressing parts (a), (b), and (c) of a homework problem. The key equations involved include the momentum equation mvr = hn/2π and the relationship between force and centripetal motion, m(v^2/r) = ke^2/r^2. The highest speed is confirmed to occur in the n = 1 orbit, with the speed expressed as v(1) = ke^2/h. The fine structure constant, defined as α = v(1)/c, is verified to be approximately 1/37.
  • Understanding of the Bohr model of the hydrogen atom
  • Familiarity with classical mechanics, particularly centripetal force
  • Knowledge of quantum mechanics concepts, including quantized momentum
  • Basic understanding of the fine structure constant and its significance
  • Study the derivation of the electron speed in the nth Bohr orbit using mvr = hn/2π
  • Explore the implications of ignoring relativity in quantum mechanics
  • Investigate the fine structure constant and its applications in physics
  • Learn about the relationship between classical and quantum mechanics in atomic models
Students of physics, particularly those studying quantum mechanics and atomic theory, as well as educators looking for insights into the Bohr model and its implications.
SucculentLamb
(a) Derive an expression for the electron's speed in the nth Bohr model.
(b) Prove that the orbit with highest speed is the n = 1 orbit,with v(1) = ke^2 / h
compare this with the speed of light , and comment on the validity of ignoring relativity (as we did) in discussing the hydrogen atom.
(c) the ratio
alpha = v(1)/c =ke^2 / hc
is called the " fine structure constant" and is generally quoted a s alpha ~ 1/37. verify this value
So, I was thinking of using (momentum) mvr=hn/2(pi) which works out to give a nice expression for the velocity, but it fails in the next two parts of the problem.
I also looked at the equation for the bohr radius: a = hbar^2/ke^2m but again, I'm not sure that this would work with the rest of the problem.
Like I said, I tried the above two equations, but neither seemed to yield an answer that would allow for solving of parts (b) and (c). Really, I would just love some help with part (a) to give me a push in the right direction. Thanks!
We know
[tex]m \frac{v^2}{r} = \frac{k e^2}{r^2}[/tex]
and
[tex]m v r = n \hbar[/tex] (the quantized momentum of the particle)
so
[tex]\frac{m v r}{r^2}v = \frac{k e^2}{r^2}.[/tex]
That should give you enough info to solve for the electron's speed!
Thanks! That was very helpful!
  • · Replies 16 ·
