Derivative discretization with fixed boundary condition
The discussion focuses on the discretization of a partial differential equation (PDE) with fixed boundary conditions, specifically addressing the calculation of the spatial derivative ∂xu at the boundaries. The initial approach uses central differences for interior points and considers different finite difference methods for the boundaries, raising concerns about accuracy. Participants discuss the use of ghost points to maintain second-order accuracy and explore the implications of boundary conditions on these calculations. It is concluded that while second-order forward and backward finite differences can be used at the boundaries, the choice of method should align with the specific boundary conditions of the problem. The thread emphasizes the importance of maintaining consistency in accuracy across the entire domain.
debsankar
Hi all,
It may be a trivial question. But, if I have a PDE of variable u(x,t)
\dot{u} = f(u,\partial_x{u},..)
with boundary condition :
u(0,t) = u(L,t) =0.
Now I need to calculate
\partial_x{u}
for that can I define the discretisation differently only on the boundary (forward / backward)?
And inside the domain(1D) I am using central difference for the perpose.
Does doing this introduce any inconsistencies in the process? Or if there is any other
standard method of doing this...
please let me know.
Regards.
Yes, that's a basic problem with finite difference methods.
The difference estimates of the derivative at the interior points are second-order accurate. If you take a forwards or backwards difference using two grid points at the boundary, that is only first order accurate.
See here for better ways to do it: http://www.scientificpython.net/1/p...-finite-differences-three-different-ways.html (these should be in any good book on FD methods).
Likes 1 person
One way of doing this is to use a fictitious point at L + Δx in the discretized central difference version of the partial derivative of u with respect to x in the boundary condition. You then substitute this discretized relationship involving the fictitious point into your discretized PDE. This preserves the second order accuracy at the boundary.
Likes 1 person
@ AlephZero >>
Thanks for the reference. I will describe a bit what I did for the completeness of the thread and also to
clear misconceptions if I have got any in this regard.
To calculate \partial_x{u} at boundaries I use >>
\partial_x{u} = \frac{-u(x+2h)+4u(x+h)-3u(x)}{2h} + O(h^2) at x=0
and
\partial_x{u} = \frac{3u(x)-4u(x-h)+u(x-2h)}{2h} + O(h^2) at x=L
and
\partial_x{u} = \frac{u(x+h)-u(x-h)}{2h} + O(h^2) for all 0<x<L
So all the discretization schemes are now second order accurate.
@Chestermiller >>
The 'ghost' points you refer to is useful if I have a condition like >> \partial_x{u} =0. But for the mentioned case its not clear to me what values I should take at the ghost points? because I don't have any condition on boundary value of the derivative. So I think
using second order forward and backward FD at the boundaries with first order central FD inside
is appropriate. Please let me know if I am missing something.
Regards,
Deb.
debsankar said:
@ AlephZero >>
and
and
@Chestermiller >>
Regards,
Deb.
To answer this question, I need to know more about the boundary conditions at the two ends. What are the boundary conditions in your particular problem?
du/dt=f(u,du/dx,..)
u(0,t)=u(L,t)=0.
This is the problem the thread started with.
Regards.
Regards.
I'm sorry. I didn't read your original post carefully enough. I totally agree with what AlephZero said regarding using one sided difference formulas to get the normal derivative to second order accuracy.
Chet
Likes 1 person
Also there is another small confusion..
say I have an eq like this >>
\dot{u} = \partial_x{f(\partial_x{u})}
and if my BC now is >>
\partial_x{u} = 0 at both ends for all time.
Now I will use the 'ghost point' method to calculate du/dx at the ends.
I will just make(in case i use central FD) >>
u(-1)=u(1) and u(n-1) = u(n+1)
this will give me du/dx =0 on boundary(i.e. for u(0) and u(n)) all the time.
But when I again calculate df/dx I will use the previously discussed method >>
@ AlephZero >>
To calculate ∂xu at boundaries I use >>
<br /> <br /> \partial_x{u}=[−u(x+2h)+4u(x+h)−3u(x)]/2h +O(h^2) at x=0 \\<br /> and \\<br /> \partial_x{u}=[3u(x)−4u(x−h)+u(x−2h)]/2h +O(h^2) at x=L \\<br /> and \\<br /> \partial_x{u}=[u(x+h)−u(x−h)]/2h +O(h^2) for all 0&lt;x&lt;L \\<br /> <br />
because, I cannot use ghost points for 'f' as I do not have the information of df/dx
at boundaries. Am I right?
If you are specifying df/dx at the boundary, then you know df/dx. But please do me a favor. Write out your DF approximation to the rhs of your pde above for point n, taking into account the zero flux boundary condition.
Chet
@ Chestermiller
I will get back to this tomorrow, I got what you said...
actually you are right I also have df/dx values at boundary...as I have du/dx.
I will explain in details my equations and what I am getting.
goodbye till then.
You don't need to make that assumption.
You can write two equations that include the "ghost point". One is the finite difference approximation to your PDE at the boundary point. The other is the finite difference approximation for the derivative at the boundary.
Then, you can eliminate the ghost point from those two equations algebraically, or you can solve the problem numerically including both the ghost points and the extra equations.
That is the third method in the link I gave. It may or may not give "better answers" than the second method - it depends on the particular equation and boundary conditions. (The link seems to say the third method will always give better answers than the second - but I'm not convinced about that).
  • · Replies 17 ·
