Derivative of Cross Product with Differentiable Functions
The derivative of the cross product of two differentiable functions, u(f(t)) and v(g(t)), is calculated using the chain rule. The correct formula is given by the expression: u'(f(t))(f'(t)) x v(g(t)) + u(f(t)) x v'(g(t))(g'(t)). This formula incorporates the derivatives of both functions with respect to their respective variables, ensuring accurate differentiation of the cross product.
  • Understanding of differentiable functions
  • Knowledge of the chain rule in calculus
  • Familiarity with vector cross products
  • Ability to compute derivatives of composite functions
  • Study the application of the chain rule in multivariable calculus
  • Learn about vector calculus and its operations, including cross products
  • Explore differentiation techniques for composite functions
  • Practice problems involving derivatives of vector functions
Students studying calculus, particularly those focusing on vector calculus, as well as educators and professionals seeking to deepen their understanding of derivatives in the context of cross products.
vroomba03
Assume that you are given differentiable function f(t) and g(t). Find a formula for the
derivative of the cross product u(f(t)) x v(g(t)).
d/dt(u(t) x v(t)) = (u'(t) x v(t) + u(t) x v'(t)
So in this case I was thinking that you would just substitute f(t) and g(t) where t would be in the regular equation, so it would be U'(f(t)) x v(g(t)) + u(f(t)) x v'(g(t)), for the equation, but I have a feeling that that's not right just because it seems too simple.
u'(f(t)) = d u(f(t))/f(t) and similar result for v'(g(t)).
What you want is d/dt ( u(f(t)) × v(g(t)) ), so you will have to use chain rule.
So then the equation would be U'(du(f(t))/f(t)) x V(g(t)) + U(g(t)) x V'(du(g(t))/g(t)) x U(f(t)) ?
No, start by applying the chain rule to find $$\frac{d}{dt} u(f(t))$$
Oh okay, so that is u'(f(t))(f'(t)) when using chain rule. So you said u'(f(t)) = d u(f(t))/f(t), so then would I divide what i got by the chain rule and divide it by f(t) and that would be my u'(f(t))?
Yes.
You need to find $$\frac{d}{dt} \left(u(f(t)) \times v(g(t))\right) = \frac{d}{dt} u(f(t)) \times v(g(t)) + u(f(t)) \times \frac{d}{dt} v(g(t))$$
You correctly found ##\frac{d}{dt} u(f(t))##. Now find ##\frac{d}{dt} v(g(t))## and substitute in.
What I should have wrote is u'(f(t)) ##\equiv## d u(f(t))/f(t), these two expressions denote the derivative of u with respect to f(t).
So the final equation for the question would be u'(f(t))(f'(t)) x v(g(t)) + u(f(t)) x v'(f(t)(f'(t)) ?
Check the last term again. v is a function of g(t), not f(t).
Oops silly error. u'(f(t))(f'(t)) x v(g(t)) + u(f(t)) x v'(g(t)(g'(t)) correct?
Correct :smile:
Thank you a bunch!
