Derivative of Geometric Series
The discussion focuses on deriving the expectation value of the function f(x,y) = (1/4^(x+y)) * (9/16) using geometric series properties. The key equation E(X) = (3/4) * Σ(x * (1/4)^x) is established, leading to confusion regarding the factor of 1/4 in the solution. The resolution involves recognizing that the extra factor arises from correctly transforming the summation into the form x * r^(x-1) and applying the derivative of the geometric series. The final result confirms that the expectation value is 1/3.
  • Understanding of geometric series and their properties
  • Knowledge of derivatives and their application in series
  • Familiarity with expectation values in probability theory
  • Basic algebraic manipulation skills
  • Study the properties of geometric series in detail
  • Learn how to derive expectation values for discrete random variables
  • Explore the application of derivatives in summation series
  • Investigate advanced topics in probability theory, such as moment-generating functions
Students and educators in mathematics, particularly those studying probability theory and series, as well as anyone seeking to deepen their understanding of expectation values and their derivations.
Saladsamurai
I am having trouble following what is going on in this solution. We are looking to find the expectation value of:
f(x,y)=\frac{1}{4^{x+y}}\cdot\frac{9}{16}
I have gotten it down to:
E(X) = \frac{3}{4}\sum_{x=0}^\infty x\cdot\left(\frac{1}{4}\right)^x\qquad(1)
We know that for a geometric series with an initial value of 1 we can write for 0 < r < 1:
\sum_{x=0}^\infty r^x = \frac{1}{1-r}
taking the derivative of both sides wrt 'r' yields:
\sum_{x=1}^\infty r^{x-1} = \frac{1}{(1-r)^2}\qquad(2)Here is where I get confused:
I thought it was a simple matter of plugging in:
\frac{3}{4}\cdot\frac{1}{(1-1/4)^2} = 4/3
However, the solution gives:\frac{3}{4}\cdot\underbrace{\frac{1}{4}}\cdot\frac{1}{(1-1/4)^2} = 1/3
I am a little confused as to where the factor of 1/4 is coming from. I am having a feeling that it has something to do with the fact that (1) runs from 0 to infinite and (2) runs from 1 to infinite.
Any thoughts?
Ah, you forgot to divide out a (1/4) in order to get the summand into the form x r^{x-1}. In particular:
\sum_{x=0}^\infty x r^{x}
Divide out an r, dropping the power in the summand down by 1:
r \sum_{x=0}^\infty x r^{x-1}
Recognize that this is the derivative of the series with respect to r:
= r \sum_{x=0}^\infty \frac{d}{dr} \left(r^x\right)
Take the derivative outside of the sum and apply your knowledge about the geometric series:
= r \frac{d}{dr} \left( \sum_{x=0}^\infty r^x \right) = r \frac{d}{dr} \left( \frac{1}{1-r} \right) = r \frac{1}{(1-r)^2}
So that r out in front is where the extra (1/4) factor comes from.
Wow, great explanation hbweb500! Thanks for the help :smile:
