Derivative of piecewise function(split in 3 regions)
  • Thread starter Thread starter marellasunny
    Derivative
The discussion focuses on calculating the derivative of a piecewise function using a specific formula for absolute values. The original formula proposed for the derivative was deemed incorrect, prompting a reevaluation. The function is analyzed in three regions: for y < -1, the derivative is zero; for -1 ≤ y < 1, the derivative equals 2; and for y ≥ 1, the derivative returns to zero. The final conclusion is that the function is not differentiable at the points -1 and 1. The calculations confirm the correctness of the derivative across the specified intervals.
marellasunny
I use the general formula: if y=|f(x)| then y'=\frac{d|f(x)|}{dx}= \frac{f(x)*f&#039;(x)}{|f(x)|} to calculate the derivative of the piecewise function given below.
Given: Piecewise function
$$h(y)=\alpha(m_1 y+\frac{1}{2}(m_0 - m_1)(|y+1|-|y-1|))$$
My attempt at calculating the derivative:
$$\frac{\mathrm{d} h}{\mathrm{d} y}=\alpha m_1+\alpha 0.5(m_0-m_1)(\frac{y+1}{|y+1|}-\frac{y-1}{|y-1|})$$, is this right?
Mathematics news on Phys.org
marellasunny said:
I use the general formula: if y=abs(f(x)) then y'= f(x)/|f(x)|
That general formula isn't correct.
Is it correct now?I edited it.
Yes and I think you have the correct answer to the problem.
Another way to look at this is to separate it unto three parts (that is, treat it as being "piecewise" as you say in your title. If y< -1, then both y+ 1 and y- 1 are negative so |y+1|- |y- 1|= -(y+1)-(-(y- 1)= -y- 1+ y- 1= -2. That is a constant so its derivative is 0. If -1\le y&lt; 1, then y+1 is positve but y- 1 is still negative. |y+ 1|- |y- 1|= y+ 1- (-(y-1))= y+ 1+ y- 1= 2y. The derivative of that is 2. Finally, if y\ge 0, both y+ 1 and y- 1 are positive so |y+ 1|- |y- 1|= y+ 1- y+ 1= 2. Again the derivative of that is 0.
So the derivative of the original function is \alpha m_1 if y< -1, \alpha m_1- (m_0- m_1) if -1< y< 1, and \alpha m_1 if y> 1. Of course, the function is not differentiable at -1 or 1.
Looking at your proposed derivative, if y< -1, so that both y-1 and y+ 1 are negative, the last part is "-1- (-1)" which is 0 while if y> 1, so that y-1 and y+ 1 are positive, it is "1- 1". If -1< y< 1, then it is "1- (-1)= 2" which cancels the "1/2" so, yes, that is the same thing.
Likes 1 person
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 21 ·
10K
  • · Replies 17 ·
  • · Replies 0 ·
