Deriving Max. Velocity for Banked Curve with Friction (Centripetal Acceleration)
The discussion focuses on deriving the maximum velocity (vmax) for a car negotiating a banked curve with friction, specifically under conditions of zero friction (glare ice). The key variables include the radius of the curve (R), the initial speed (v0), and the coefficient of static friction (µ). The equations of motion, including centripetal acceleration (v^2/R) and the forces acting on the car, are utilized to establish a relationship between these variables. The proposed approach involves using trigonometric relationships and Newton's second law to derive the formula for vmax.
  • Understanding of centripetal acceleration and its formula (v^2/R).
  • Knowledge of static friction and its role in motion (F = µN).
  • Familiarity with trigonometric functions and their application in physics.
  • Basic grasp of Newton's laws of motion.
  • Derive the formula for vmax using the equations provided in the discussion.
  • Explore the impact of varying the coefficient of static friction (µ) on vmax.
  • Investigate the effects of different radii (R) on the stability of a vehicle on a banked curve.
  • Study real-world applications of banked curves in highway design and vehicle dynamics.
Students in physics or engineering, automotive engineers, and anyone interested in the dynamics of vehicles on curved paths, particularly in relation to friction and banking angles.
Novii
A circular curve of radius R in a new highway is designed so that a car traveling at speed v0 can negotiate the turn safely on glare ice (zero friction). If a car travels too slowly, then it will slip toward the center of the circle. If it travels too fast, then it will slip away from the center of the circle. If the coefficient of static friction increases, a car can stay on the road while traveling at any speed within a range from vmin to vmax.
Derive formula for vmax, as a function of µ (coefficient of static friction), v0, and R.
F=ma
centripetal acceleration = v2/R
Force of static friction = µs * N
I tried expressing the angle of the bank with v0 and R first, then substituting it in for equations found for vmax:
θ=arctan((v0^2)/(9.8R))
x: sinθN + cosθFfr= ma= m (vmax^2)/R
y: mg + sinθFfr= cosθN = 9.8m + sinθ * µ* N
Where θ is the angle of elevation, N is normal force, and Ffr is friction force.
But the x and y equations turned out to be pretty complicated, and I'm not sure how to proceed now. Are my equations right?
Your equations look fine. Rearranging them slightly, you get
\begin{align*}<br /> N\sin\theta + \mu N \cos \theta &amp;= mv_{max}^2/R \\<br /> N\cos\theta - \mu N \sin \theta &amp;= mg<br /> \end{align*}<br />
Try dividing the first equation by the second and go from there.
  • · Replies 19 ·
