Design of floor joists in a domestic building
  • Thread starter Thread starter john paul jr
    Building Design
6 replies · 6K views
john paul jr
Could i have some help with the following:
Design, floor joists in a domestic building to span between walls 3.0m apart.
the construction of the floor is
18mm timber boards
joists
15mm overall plasterboard + skim coat
The joists are 50mm wide and at 450mm centres
The permissible stress in the timber is 5.3N/mm(squared) and the elstic modulus of the timber is 8000N/mm(squared)
the deflection must be limited at 0.3% of the span.
18mm timber boards
joists
What is your background? What city is this in? What are the local codes regarding this kind of construction? You need a licensed engineer to make those calculations for you -- one who is familiar with your municipality's building codes and inspectors.
Is this homework? If not, there's not much of a chance for getting an accurate result without knowing local building codes.
Even if we had a PE structural engineer as a member or on staff, we wouldn't condone giving such advice since we can't be sure this isn't a code violation (a homeowner trying to do his own structural engineering).
Thanks for getting back to me this is actually a college assignment that I've been stuck on for quite a while that i needed help on for designing the floor joists.
Ok so is a college assignment. Start off by showing your work, so we can know with what you are having problems.
john paul jr: Do you have the density of the timber boards, and of the joist material? Do you have the density of plasterboard? Do you have the floor applied live load per unit area?
