Designing a Beam to Carry a Concentrated Load
  • Thread starter Thread starter hils0005
    Beam Design
The discussion revolves around the design of a beam intended to carry a concentrated load at its midpoint, specifically for a drafting class project. Participants explore various beam designs, materials, and structural considerations, focusing on a 4ft span and a weight limit of 12oz.
  • One participant is considering a V-type web truss made of pine, noting that while pine has a greater modulus of elasticity than balsa, its higher density may pose weight challenges.
  • Another participant clarifies that the beam should be simply supported with pin reactions only in the vertical direction.
  • There is a suggestion to consider a castellated beam or a box beam design.
  • A participant raises considerations regarding the loading type, questioning whether it will be subjected to 2-point or 4-point bending, and discusses the implications of using a V-type design in terms of stress and load path.
  • One participant advocates for a simple I-section beam due to its efficiency in maximizing the second moment of area while minimizing connections, suggesting that a truss system may complicate construction and reduce load capacity.
  • Another recommendation is to use Fiber Reinforced Polymer (FRP) to enhance the I-section, emphasizing the importance of aligning the fiber direction with the principal loading plane.
  • A link to a website selling carbon fiber I-beams is provided as a resource for materials.
Participants express differing opinions on the optimal beam design, with some favoring traditional I-sections for their structural efficiency, while others propose alternative designs like V-type trusses. The discussion remains unresolved regarding the best approach to meet the project requirements.
Participants mention various assumptions about loading conditions and material properties, but these assumptions are not fully explored or agreed upon, leaving some aspects of the design criteria open to interpretation.
hils0005
for one of my drafting classes I have to design a beam. The beam needs to carry a concentrated load at the midpoint.
some parameters:
4ft span
total materials must weigh under 12oz
Pin reactions at the ends
the person last year that won(highest load) made a simple I joist out of Balsa. I'm wondering if anyone has any experience in this project.
I am thinking of making a Vtype webtruss out of pine, I know mod. of Elasticity for pine is greater than balsa, but more dense which I may run into problems with the weight.
Any suggestions?
Pin reactions at both ends?
sorry, simply supported rigid beam, reaction only in the y direction, no x or moment
Castellated beam or box?
hils0005: a couple things to consider.
How is it loaded, will it be 4point or 2 point bending, if 4point and region of constant moment midspan on a 4ft span a 'V' might see a quicker load path but have higher stress do to the off center applied loading.
Why a simple I section is so effective is because it's maximizing 2nd moment of area while minimizing connections. Your truss system may theoretically have a higher capacity but the constructability of all those pieces joining increases your chances of never seeing the full loading potential simply because of how it was made.
Recommendation: if there are no material restrictions get a hold of some Fiber Reinforced Polymer wrap and make another simple I section, but epoxy the wrap to your section. Making sure the direction of the fiber matches the principal plane of loading. FRP is very light and could be cut, if you find your I section is getting close to the 12oz marker and can't wrap the entire member, wrap the critical sections specifically the two web members.Hope this helps.
Try this site:
http://www.dragonplate.com/ecart/categories.asp?cID=84"
They actually sell carbon fiber I-beams and a lot of other stuff.
12K
11K
20K
