Designing a Deterministic Finite Automaton for Binary Input and Output Sequences
  • Topic:
  • Thread starter Thread starter evinda
    Machine
12 replies · 3K views · last reply
evinda
MHB
Hello! (Wave)
A dfa with three states has as input and output alphabet the set $\{0,1\}$.
Given the following input sequence and the corresponding output sequence , we should determine the automaton.
$ \text{ Input }: 00010101 \\ \text{Output: } 011001110$
First of all, the output should have a typo and we should ignore the last 0, so that the number of digits of the input and the output sequence is the same. Right?
Secondly, could you give me a hint how to draw such a deterministic automaton?
evinda said:
Hello! (Wave)
Hey evinda! (Smile)
Let's assume for now that it's a typo, or otherwise that we output $0$ when we enter the final state.
And let's assume we have no restriction on the number of states.
Then we can draw the following state diagram (using the new tikz picture functionality :cool:):
\begin{tikzpicture}[->, >=stealth', shorten >=1pt, auto, node distance=2cm, semithick, bend left]
%preamble \usetikzlibrary{arrows,automata}
\tikzstyle{every state}=[top color=yellow!30!white,bottom color=yellow,draw=orange,text=black]
\node[initial,state] (A) {A};
\node[state] (B) [right of=A] {B};
\node[state] (C) [right of=B] {C};
\node[state] (D) [right of=C] {D};
\node[state] (E) [right of=D] {E};
\node[state] (F) [right of=E] {F};
\node[state] (G) [right of=F] {G};
\node[state] (H) [right of=G] {H};
\node[state,accepting](I) [right of=H] {/0};
\path (A) edge node {0/0} (B)
(B) edge node {0/1} (C)
(C) edge node {0/1} (D)
(D) edge node {1/0} (E)
(E) edge node {0/0} (F)
(F) edge node {1/1} (G)
(G) edge node {0/1} (H)
(H) edge node {1/1} (I);
\end{tikzpicture}
Can we reduce the number of states? (Wondering)
I like Serena said:
Hey evinda! (Smile)
\tikzstyle{every state}=[top color=Goldenrod1!30!white,bottom color=Goldenrod1,draw=DarkOrange1,text=black]
\node[initial,state] (A) {};
\node[state] (B) [right of=A] {};
\node[state] (C) [right of=B] {};
\node[state] (D) [right of=C] {};
\node[state] (E) [right of=D] {};
\node[state] (F) [right of=E] {};
\node[state] (G) [right of=F] {};
\node[state] (H) [right of=G] {};
\end{tikzpicture}
The dfa you drew is equal to the following one, right?View attachment 6077
Can we make further changes? (Thinking)
Yes. Although we don't have a final state anymore now... :eek:
I think so.
I've added letters to my previous post for ease of reference.
I think we can collapse B, C, D, and E to a single state, since the transitions between them are uniquely the same. (Thinking)
I think that when we have also outputs the existence of final states is not necessary, is it?
I like Serena said:
I think so.
The transitions have as input and output $0/1, 0/1, 1/0$. Why can we collapse B, C, D, and E to a single state? I haven't really understood it... (Worried)
\end{tikzpicture}
Let's start from the left, and let's try to collapse some of the states.
Suppose we try to collapse A and B, then we'll get:
\begin{tikzpicture}[->, >=stealth', shorten >=1pt, auto, node distance=2cm, semithick]
\tikzstyle{every state}=[top color=yellow!30!white,bottom color=yellow,draw=orange!80!black,text=black]
\node[initial,state] (AB) {AB};
\node[state] (C) [right of=AB] {C};
\path (AB) edge[loop above] node {0/0} (AB)
(AB) edge[bend left] node {0/1} (C)
(C) edge[bend left] node {0/1} (D)
(D) edge[bend left] node {1/0} (E)
(E) edge[bend left] node {0/0} (F)
(F) edge[bend left] node {1/1} (G)
(G) edge[bend left] node {0/1} (H)
(H) edge[bend left] node {1/1} (I);
\end{tikzpicture}
Is this the same state machine?
If so, can we collapse C to AB in the same way, or will that introduce a conflict? (Wondering)
\end{tikzpicture}
Sorry, that was not correct, because now it's ambiguous where 0 should go in state AB.
Instead it should be:
\node[state] (BCD) [right of=A] {BCD};
\node[state] (E) [right of=BCD] {E};
\path (A) edge[bend left] node {0/0} (BCD)
(BCD) edge[loop above] node {0/1} (BCD)
(BCD) edge[bend left] node {1/0} (E)
\end{tikzpicture}
How can we continue? (Wondering)
\tikzstyle{every state}=[top color=Goldenrod1!30!white,bottom color=Goldenrod1,draw=DarkOrange1!80!black,text=black]
\end{tikzpicture}
But now after we have printed 0 after giving 0, we can give how many 0s we want and the machine will print 1. Doesn't this matter? (Thinking)
No, because we're given what the input is. (Shake)
We just have to make it match the output without ambiguity.
If the input is $000101010$ and the output this : $011001110$ the desired dfa is of the following form, right?
Yep. Looks like it! (Nod)
Nice! (Smile)
