Designing a Stable Crane: Finding Reactions & Max Load
The discussion focuses on designing a stable crane by calculating the reactions at the jib and determining the maximum load it can lift. The user established that the maximum weight the crane can handle is 600 kg, translating to a force of 6000 N. The calculations involve ensuring that the sum of all forces equals zero and that the moments at the base of the vertical beam are balanced. The user seeks to confirm the stability of the crane under these conditions and the reactions at the intersection of the horizontal and vertical beams.
  • Understanding of static equilibrium in mechanics
  • Knowledge of crane design principles
  • Familiarity with force and moment calculations
  • Basic concepts of pulley systems
  • Research static equilibrium principles in mechanical systems
  • Study crane stability analysis techniques
  • Learn about calculating moments in structural engineering
  • Explore pulley system mechanics and load distribution
Mechanical engineers, civil engineers, and students involved in structural design and stability analysis of cranes and lifting systems.
dreistein
I'm to design a crane, and therefore I need to find the reactions in the jib and also make the crane stable.
1. I need to find the max. load that the crane is able to lift. Therefore i have to find the reactions where the horisontal and vertical boom is meeting.
2. I need to find out the moment in the bottom of the vertical beam in order to make the crane stable. Now i should have the max weight, and therefore the weight of the stone. And it should be easier to calculate
The sum of all the forces needs to be 0. F=0
The angle is 90 degrees, so that is not going to be a problem
The wire from the horisontal beam is only ½ m.
But since i don't know the weight of the stone, I don't know where to begin?
as I'm using a pulley system i found out that my weight max is going to be 600 kg, but is my crane able to do this? What will the reactions be where they meet each other? And will they be able to lift this?
I assume that the reaction would be: moment = 0, 6000N*3m-R*3m=0
Therefore Reaction where the beams are meeting would be 6000N
9K
19K
  • · Replies 69 ·
  • · Replies 17 ·
