Designing a Wood Truss with Medeek Calculator App
The discussion revolves around the development and features of a web-based app designed to calculate forces within wood trusses, particularly focusing on the Fink truss type. Participants explore various aspects of truss design, including moment calculations, tension and compression analysis, and the integration of features like AutoCAD file generation. The conversation encompasses both technical challenges and educational applications of the tool.
  • One participant describes the app's capabilities, including support for common truss types and future enhancements like chord and plate sizing.
  • Another participant expresses enthusiasm but notes the app's lack of metric units.
  • A participant discusses challenges with moment calculations, referencing standards and seeking advice on matrix methods for analysis.
  • Another participant shares progress on tension and compression analysis, highlighting difficulties with current standards compared to previous editions.
  • A participant mentions the addition of an AutoCAD file generator for usability in design.
  • Concerns are raised regarding the analysis of box beam trusses, with a request for calculators specific to that type.
  • One participant provides insights on the importance of fasteners and spacing in box beam construction.
  • Another participant reports completing a full lumber analysis for the Fink truss and plans to expand the app to include more truss types.
  • A participant shares success in implementing matrix analysis, noting the accuracy of results compared to other modeling software.
  • Concerns are expressed about the assumptions made regarding joint fixity and its impact on bending moments and loads.
  • One participant critiques the treatment of peak joints and discusses efforts to model them as pinned connections, referencing relevant literature for guidance.
Participants express a range of views on the technical challenges of truss analysis and the implications of different modeling approaches. There is no clear consensus on the best methods for handling joint fixity or the adequacy of current standards, indicating ongoing debate and exploration.
Participants mention limitations in current standards and the absence of example calculations in newer editions, which may affect their analyses. There is also uncertainty regarding the effects of joint rigidity on bending moments and load distribution.
This discussion may be of interest to engineers, designers, and students involved in structural analysis, particularly those focusing on wood truss design and related computational tools.
medeek
I recently started programming a basic web based app. that calculates the forces within a standard wood truss. I thought it might be of some interest to visitors to the Physics forums. I've added most of the common types of trusses used in residential construction, with more to come later. The backend is programmed in Perl with some MySQL for tables and data. In the near future I will also add in chord sizing and plate sizing to further complete the truss analysis and design. My intent is to provide a high quality tool for other design professionals and to also provide a clear view to the public on what goes on behind the scenes in the design of the roofs of 90% of the new construction in the nation.
Here is the output for a double fink truss with a 40ft. span.
The link to the proto-type web based app. is here:
http://design.medeek.com/calculator/calculator.pl
I'm also hoping that this tool can be used for educational purposes, help students see how the concepts of forces and vectors are used in real life applications to design structures.
This is awesome! Unfortunately it is not in metrics unit. BUT STILL AWESOME YO!
Moment Calculations
I've kind of hit a road block on the moment calculations for my truss designer project. The current spec TPI 1-2007 calls for using the matrix method in determining the moments. However, I need to be able to run this app without doing a full blown analysis using RISA or some other FEA type product. For now I've gone with the simplified method which is the method used in the TPI 1-1995 standard, at least I can produce a solution.
If anyone has any ideas on how to do a simple matrix method analysis of a common fink truss please send me in the right direction. My biggest unknown with this would be how to deal with the fixity of joints at panel points and heels. I've just ordered a copy of Hibbeler's Structural Analysis to further research how best to deal with frames, trusses etc...
One thing I found really helpful was the samples provided in the previous editions of the TPI 1, its really quite disappointing to see no such example calculations in the current standard (2007).
Here is a typical output for a fink truss showing moment calculations:
I also added deflections calculations using the virtual work method, curious to see how this stacks up against an identical truss with same loads and lumber analyzed with Mitek or Alpine:
I will keep developing this app as time allows. My next challenge is to use these moment values to analyze each chord member and appropriately size and select the type and grade of lumber for its construction. This is now getting into the real engineering whereas the previous calculations were just basic (statics) physics and math.
I've just completed the tension and compression analysis for the web members for the fink truss. It took a little longer than expected but most of that was comparing notes between the TPI, NDS and "Design of Wood Structures" text. The rest was trying to format the equations correctly with html and finally resorting to LATEX and a third party program. Below is part of the calculations for a 4/12 fink truss:
My next hurdle is to try and program the top and bottom chord analysis however I am having a bit of trouble making sense out of the TPI 1-2007 when it comes to calculating the effective lengths for the chords, the previous method used in TPI 1-2002 seems a whole lot simpler than the current standard, it will probably take me a few days to mull it over. Once that is done a heel analysis and then all of the metal plates analysis and then its done. However, so far I have not introduced any short term loading due to wind or seismic so in the future I may attempt that as well.
I also added an AutoCAD (.dwg) file generator so that the geometry of the truss is in a usable format for other designers, typical output below:
Box Beam Truss
Nice program. Unfortunately for me, it does include enclosed box beams. I am supporting the second floor of my workshop with box beams constructed out of 2X4s and faced on both sides with 1/2" oriented strand board. Anyone know a calculator for this type truss/beam?
I think the key there would be the type of fasteners and spacing connecting the OSB to the 2x4 (flanges). Unfortunately, I'm not familiar with that type of beam, but it does seem like it should work reasonably well.
I've added a bearing check and completed the full lumber analysis to the fink type truss. Now working on the metal connector plates, then I will replicate the analysis to all the other truss types. Also would like to add three additional truss types: Howe Scissor, Mod Queen Scissor, Double Howe Scissor.
After about a good week of solid programming and scratching my head I've finally managed to add the requisite Matrix Analysis to my Truss Calculator. Thank-you R.C. Hibbeler for your Structural Analysis text on the subject (ch. 14 - 16), if the subject had not clearly laid out in front of me I would never have figured out the numerous steps to arrive at the solutions.
Here is an example of the output of my matrix analyzer for the Fink truss:
I've even inserted the correct code to account for the additional loading/moments if there are overhangs. I double checked my work by modeling up identical trusses (beams and trusses members) in both Strand7 and Solidworks (COSMOS/Simulator). My result were within 1.5% or better, so I'm really happy about that.
My only concern with my analysis is how correct my analog for the truss really is. What I mean is that the bending moments are heavily influenced by the amount of rigidity of the joints. Fixing the joints (where chords meet) or pinning them dramatically affects the bending moments and even the axial and shear loads to some extent. My analog model is basically rigid at the heel and peak joints and pinned at all other web-to-chord or web-to-web joints. This seems to approximate most closely the moments calculated using the simplified method (pre TPI-2002). The nice thing about the matrix model is that I can easily pin or fix joints depending on how I want to model the truss. I might even add in some logic so that the user can pin or fix certain joints just to see how it affects the final loading and member design of the truss.
What I also found quite interesting (and expected) is if you use a stronger type of lumber on the top chord as compared to the bottom chord. The top chord loads increase and the bottom chord loads decrease. The matrix analysis is almost as good as FEA. It's really quite cool to be able to calculate something like this just using a bunch of matrices.
Impressive Project!
Leaving the peak joint as a rigid connection without exploring the implications of a pinned or semi-rigid joint seem like a cop-out to me so I spent most of the day attempting to release the peak joint so that it could act as a pinned (zero moment transfer) joint. For the web members I accomplished a similar task by altering the 6x6 stiffness (k') matrix so that it only included the axial terms, thereby eliminating any shear or moment forces, making these members axial only or simple pinned truss members. However, for the top chord members it was not such an easy task. I initially tried eliminating the row of the matrix that was responsible for the far end moments (pinned end), but it some became apparent that the interplay between moments and shear forces was more than I had originally thought. I was about to accept defeat but then after spending a couple more hours digging about online I came upon a gem of a paper published in 2010 in the Electronic Journal of Structural Engineering by M. E. Kartal. This paper outlined a couple of methods for obtaining the correct stiffness matrix for semi-rigid connections. With this information I was then able to add in feature so that one can select whether the peak joint is rigid, semi-rigid or pinned.
I then tested it for accuracy against an identical model in Solidworks Simulator for both the pinned and rigid connection at the peak joint with near perfect results. Unfortunately, Solidworks does not allow for adjusting the rigidity of connections between beams in its interface so I currently do not have the tools to test the accuracy of the semi-rigid model. However it appears to present the correct trends when compared against the other two options. If someone has a copy of ANSYS or some other reasonably high end FEA software I would be interested to see how well it will compare with third party verification.
Starting to work on the modified queen truss, here is the schematic for the matrix analysis of it. The structure stiffness matrix will be a 30 x 30 matrix (900 values), its no wonder they didn't do this sort of thing prior to our modern computers, imagine trying to calculate this by hand. :)
Compare this to the fink truss, which has a few less webs and hence the computations are less 21 x 21 matrix (441 values)
These schematics really say nothing about which members are pinned, semi-rigid or rigidly connected. The stiffness matrix (k) for each member is what determines that.
In my analysis I am treating all of the webs as pinned jointed on both ends and only capable of transferring axial loads (classical truss members). The top and bottom chords at panel points are treated as rigid connections. The peak joint is treated either as rigid, pinnned or semi-rigid, this is user configurable. The heel joint is treated as rigid or semi-rigid. My reasoning and justification for these model settings is based on a number of papers I have compiled on the rigidity of joints of MPC wood trusses. I have saved each one and will compile a reference list at some point to accompany the truss designer documentation.
These two papers especially the bottom one were quite helpful:
http://design.medeek.com/resources/truss/DOCUMENTS/Paper_124.pdf
http://design.medeek.com/resources/truss/DOCUMENTS/20103.pdf
Currently working on the plate calculations. Those will be rather lengthy but the upside is the summary is what most people will want or need, however I will show each lateral resistance, tension, shear, net section and moment check for each plated area of each joint. I'm doing one by hand first before I code it and I've already used 10 pages for the calculations and I still have to add the heel joint. I hope if nothing else people can use this app to at least better appreciate all of the checks that go into a simple truss.
26 pages of truss plate calculations for one simple fink truss.
It's no wonder we use computers for this sort of thing.
Now I just need to take it from this pseudo-code into Perl code with a bit of fancy logic and we've got her licked. :)
Updates:
Version 1.0.5 - 07.26.2014
- Added lumber species selection under advanced options.
- Tension perpendicular to grain check added for joint (6) and (7).
- Updated AutoCAD drawing generator so that it now draws the metal connector plates at the correct sizes.
- Limited heel joint plate selection algorithm so that the heel plate is single, symmetric and does not exceed bottom chord depth in height.
I haven't posted about the truss designer for a while, apologies for that.
Still trying to improve it as time allows. The list of upgrades and improvements was getting rather lengthy so I've created a changelog page here:
http://design.medeek.com/calculator/changelog.html
Unfortunately, I had to put a daily limit on its usage because the server was getting hammered but it is still free to use.
The biggest improvement is the ability to specify the lumber grade, size and species as well as utilize point loads. This should make this tool far more useful for those wanting to check their roof for solar panel installations.
I'm still thinking about generating a 3d model for those wanting to import the truss directly into programs like Sketchup or REVIT
I appreciate all of the support I've received over the last couple of years on this project. Suggestions/feedback is always awesome.
Added SketchUp 3D (.rb) file output for the truss geometry. This file, when copied into the SketchUp plugins folder, will create a menu item within SketchUp allowing for unlimited creation of the given truss geometry within SketchUp. I think this feature will be particularly interesting to those DIYers who wants to draw up their own model and plans using SketchUp.
I've updated the code so that the plugin now allows for user input in order to specify number of trusses and spacing of the trusses. For example 4 trusses @ 24" o/c would give you:
The actual truss geometry cannot be altered within SketchUp it is hard coded into the plugin when it is created by the calculator. For different truss sizes and shapes it is simply a matter of creating and storing separate .rb files for them. Dropping these files into the SketchUp folder sets up the menu item. This method seems to be the easiest for interacting with the SketchUp API.
I'm trying to make this easier to use for the SketchUp user and for the designer who does not need a bunch of engineering information. I've created a separate plugin that is used to generate the truss geometry (no engineering or loads). Please feel free to beta test it here:
http://design.medeek.com/calculator/sketchup/
Drop the .rbs file into your SketchUp plugins folder. Suggestions or bug notifications are welcomed. Currently only the King Post, Queen Post and Fink truss type is available but I will add the others shortly.
I have the raised/energy heel working now for a fink truss where a vertical member and strut is required (heel height greater than 12" approx.). Still working on the wedge and slider cases, they are actually easier to calculate and program, but I figured I would tackle the difficult one first.
When the angle between the strut and top chord exceeds 10 degrees I then apply a scarf cut to the strut at its centerline (try a raised heel height that exceeds 24" and you will notice the difference).
Here is an example of a fink truss with a 18" raised heel. Notice there is no scarf cut at the top of the strut where it meets the top chord.
This is the same truss I used in my 28'x48' garage:
Now I need to work on the energy heel option for this truss as well as some additional logic for attic trusses in the following span ranges 16-24 feet and 30-36 feet.
Howe truss type is now active.
The latest plugin version is 1.0.4. I would highly recommend downloading the latest version since I have also spent some time this morning cleaning up my code and removing global methods and variables so that I don't clash with other extensions or modules.
Version 1.0.5 - 10.24.2015
Added Scissor truss type, configurations: (2/2), (4/4).
Metric input enabled for scissor truss types.
In certain instances the scarf length of the bottom chord becomes less than the bearing length, the logic checks for these cases and inserts either a 3.5 or 5.5 heel wedge as required.
Just playing around with SketchUp a bit today and trying out the new sheathing, rakeboard and fascia capabilities in the Plugin.
The roof of this simple structure took all of 10 seconds to create, the rest about 20 minutes. I didn't realize Simpson Strongtie hardware is available in the 3D warehouse, good to know.
I'm not going to say anything about lateral bracing of this structure, just modeling for fun.
One can go so far as to put all of the H1 ties in. I could waste an entire day messing around in this software, way too much fun.
Version 1.1.6 - 11.26.2015
- Added Fan and Mod Queen common truss types.
- Structural outlookers (vert. & horz.) enabled under advanced roof options for Common (Fan & Mod Queen) truss types.
Four more common truss types still need to be added:
- Double Howe (6/6)
- Mod Fan (8/4)
- Triple Fink (8/7)
- Triple Howe (8/8)
For very large buildings one could also consider:
- Quad Fan (10/5)
- Quad Fink (10/9)
- Quad Howe (10/10)
- Quin Fan (12/6) ...
A quad fink truss (10/9) with a raised heel (slider):
http://www.selecttrusses.com/wp-content/uploads/Ag1.jpg
Valley Sets are here:
Proceed with caution though I just put it together so it is still a bit rough around the edges. Further testing and refinement is necessary but it seems to be working fairly decently.
Currently the main roof plane and two points need to be selected rather carefully I'm not sure I can do much about that, if not I will need to document in some detail how to use this function.
I see your plugin is a featured extension in the latest SketchUp newsletter. Nice work :smile:
Yesterday I noticed a spike in traffic on the server, pleasantly surprised that the reason was not a hacker/spammer attack and an actual good reason for the increased bandwidth. Now I just need to spend more time at this plugin so as to not disappoint.
9K
12K
  • · Replies 42 ·
  • · Replies 27 ·
