Determinant proof from abstract algebra
7 replies · 3K views
brydustin
Let A be a a square n*n matrix. Prove that A^-1 has only integer enteries if and only if the determinant of A is + or -1.
general knowledge of determinants
Proof:
Suppose that det(A) = 1 (without losing generality, i.e. if det(A) = -1, then det(-A) = -det(A) = 1, easy enough).
So if det(A) = 1, then it follows that det(A^-1) = 1 because
1 = det( I ) = det(AIA^-1) = det(A) *det(I) * det(A^-1) = 1*1*det(A^-1) = 1, which implies det(A^-1) = 1 (or -1 if det(A) = -1).
Now what?
Suppose that all the enteries of the matrix A^-1 are integer,...
I have no clue what to do now...
Sorry I did a slight misquote of the website from where I pulled the problem:http://ocw.mit.edu/courses/mathematics/18-701-algebra-i-fall-2007/assignments/
first question on first assignment.
Basically, assuming that A is a square matrix with integer entries only; then prove that A^−1 has integer entries if and only if the determinant of A is ±1.
Sorry about that: so your matrix would not be a counter-example because neither it nor its inverse has only integer. Equivalently, if one matrix is all integers with a determinant of +-1 then the inverse of this matrix will also be an integer only matrix with the same determinant.
lanedance said:
what about
|0.5 0|
|0 2|
--> A^-1 has only integer entries
so as A^-1 exists, then the determinant of A is non-zero. Think of the effect of elementary row operations on the determinant to reduce the matrix to the identity...
micromass said:
Maybe you can use that [tex]det(A^{-1})=det(A)^{-1}[/tex]...
Exactly. If both A and [itex]A^{-1}[/itex] have integer entries, then their determinants are integers. Find integers, m and n, such that m= 1/n!
Going the other way, if the determinant of A is -1 or 1, use the fact that the entries of [itex]A^{-1}[/itex] are the cofactors of A divided by det(A).
Yeah... I see it now, almost... it seems obvious but I may be missing a piece...
Because the determinant operation is only multiplication and subtraction it preserves the integers (from A). On the other hand, we require that det( [itex]A^{-1}[/itex]) =+-1 because 1 = det (I) = det(AIA^-1) = det( A)*det(I)*det( [itex]A^{-1}[/itex]) = (+-1)(1)(det [itex]A^{-1}[/itex])
Now that the det of [itex]A^{-1}[/itex] is +-1 I still don't know why we require the entries to be integers. I see how having integer entries would result in an integer determinant, but I don't see the converse.
Going the other way around, if [itex]A^{-1}[/itex] has integer values then clearly its determinant will be an integer.
Now if we use the fact that det(A)^-1 = det(A^-1) then why should that make det(A) = +-1?
Let d = det(A^-1) where d is an integer. There is nothing that requires det(A)^-1 to be an integer. There are some holes in the logic we have... but we're nearly there...
