Determine if a transformation is linear.
The discussion revolves around determining whether two transformations are linear. The original poster attempted to apply definitions of linearity but expressed uncertainty about their correctness. It was concluded that neither transformation satisfies the linearity conditions, specifically T(u+v) = T(u) + T(v) and T(cu) = cT(u). To further validate this, specific numerical examples should be provided to demonstrate the failure of these conditions. The conversation emphasizes the importance of clarity in presenting conclusions about linearity.
thatguythere
Please see attached files and let me know if I am correct or not.
Can't say whether you are correct or not. You just wrote a bunch of stuff down. Are they linear or not?
What do you mean, I just wrote a bunch of stuff down? They are two separate transformations. I applied arbitrary vectors to them and attempted to prove if T(u+v) = T(u)+T(v) as well as T(cu)=cT(u)
In the first transformation, it appears that the first definition is not satisfied and in the second problem, the second definition is not satisfied. Therefore, I do not believe either are linear, however I am not certain if I am doing this properly.
That's exactly what I was asking for. I wanted to know your conclusions from what you wrote down. Correct that thay are both not linear. If you want to prove that just come up with specific examples of u, v and c (with numbers in them) where T(u+v)=T(u)+T(v) or T(cu)=cT(u) don't work.
Since when is 3^a + 3^b = 3^{a+b}?
That was my point. Just writing these things down doesn't say whether the poster believes them to be correct or incorrect. I'm not sure what writing a check next to it means.
9K
  • · Replies 16 ·
