Determine ruling from grating constant
  • Thread starter Thread starter Alexandra7
    Constant Grating
The discussion centers on calculating the ruling (number of lines per meter) from the grating constant, specifically using the formula N = 1/d. With a grating constant of 1.6555 x 10^-6 m, the calculated number of grooves is approximately 604,230 grooves/m. Participants confirm the calculation's validity and encourage the user to understand the relationship between the grating constant and the resulting number of lines, emphasizing the importance of grasping the underlying physics concepts.
  • Understanding of the grating constant in optics
  • Familiarity with the formula N = 1/d for calculating grooves per meter
  • Basic knowledge of unit conversions, particularly between meters and millimeters
  • Concept of how physical spacing relates to line density in diffraction gratings
  • Study the principles of diffraction gratings and their applications in optics
  • Learn about unit conversions, especially between meters and millimeters
  • Explore examples of calculating line density for various grating constants
  • Review related physics concepts such as wave interference and light behavior
Students studying optics, physics educators, and anyone preparing for exams involving diffraction gratings and related calculations.
Alexandra7
If "d" is the grating constant, determine the ruling (number of lines/grooves per meter) "D"
I have spent hours researching sites that are far too complicated for my understanding of physics. As a result the only relevant equation I could remotely relate to this problem is as follows:
N= 1/d
N= 1/1.6555x10^-6m
= a really big number! such as 604,230 grooves/m or lines/mIt just doesn't make sense and I'm getting upset!
Please, pretty please with a cherry on top, is anyone able to help me? Physics is by far my worst subject but I'm trying!
N= 1/d
N= 1/1.6555x10^-6m
Seems like it might be OK to me. 604,000 grooves/m is 6040 grooves in a centimeter. You didn't give the grating constant in your problem statement, but assuming that number is correct and your formula is correct, I don't see a problem. Do you have the answer available?
First of all, thank you for your contribution.
Unfortunately my textbook does not include a solutions manual so I can only try, then hope for the best. My professor said we would have a question similar to this one on a test which is why I'm freaking out.
The grating constant is 1.6555x10^-6m
If the grating constant is the gap between consecutive lines then the number of lines per unit distance is clearly just the inverse of this. Your answer must be right.
... you are going to have to get used to how numbers behave.
Try checking your reasoning with something you are more used to:
If d=1mm, then N=1000 lines/meter right?
The short lines on a meter-rule are 1mm apart: how many of them are there?
For your example, d ~ 1000th of a millimeter - so how many lines are there in 1mm?
... how many of those groups are in 1m?
... so how many overall?
You actual d is slightly bigger than that so you'd get slightly fewer lines per meter - is your number consistent?
