Determine the compression in the spring
7 replies · 3K views
rrosa522
A 1.2 kg glider moving at 3.0 m/s right
undergoes an elastic head-on collision with a glider of equal mass moving at 3.0 m/s left . T​
he collision is cushioned by a spring with k=6.0*10^4 N/m. Determine the compression in the spring when the second glider is moving at 1.5m/s. Ans =1.6cm
same mass therefore..
vf1= Vi2
vf2= Vi1
I think I would be able to do this question if could understand it. Is the initial velocity of the second glider 3m/s or 1.5m/s?. I would really appreciate if someone can explain this question to me because I really don't know where to start.​
The equations given refer to the exchanged velocities after the collision wen they are not again in contact with each other. The question has been asked about the state when they are still existing force on each other through the spring. At that instant apply energy and momentum conservation.
TSny said:
Initially, before the collision, each mass is moving at 3.0 m/s.
My teacher told me that when the masses are identical then vf1= Vi2 and vf2= Vi1, so how is it even possible that vf2=1.5m/s ?
Your teacher is right but does that happen in zero time just try to visualize the situation. Both change their momentum over a period of time called collision time. This time cannot be zero why. Why think it over. Suppose collision time is zero what will be the rate of change of momentum?
the momentum of both bodies wouldn't change if collision time was zero
It is given in the problem that the velocity of one has changed from 3.0 to 1.5. So what will be the velocity of the other as per conservation of momentum? Where has the KE of both gone?
That applies when 'final' refers to the completion of the collision process. It is clearly not true during the process. E.g., at some point they must both be instantaneously stationary.
