Determine the particles most probable position
10 replies · 3K views · last reply
Addez123
x > 0:
$$\Psi(x) = 2\sqrt{a^3}xe^{-ax}$$
x < 0:
$$\Psi(x) = 0$$
Physics
To get expected value I use
$$E = \int \Psi^* Q \Psi dx$$
where Q = x
$$4a^3 \int xe^{ax} \cdot x \cdot xe^{-ax} dx = 4a^3 \int_0^{\inf} x^3 dx$$
which is undefined.
But the answer is suppose to be 1/a.
Addez123 said:
Homework Statement:: x > 0:
x < 0:
$$\Psi(x) = 0$$
Relevant Equations:: Physics
where Q = x
which is undefined.
What is ##\Psi ^*## again? (Hint: a is real.)
-Dan
-Dan
Isn't the conjugate simply reversing the minus sign on the exponential?
Conjugate of ##xe^{-iax}## is ##xe^{iax}## according to wolfram alpha too.
The argument of your exponential is -ax, not -iax.
-Dan
-Dan
That is true!
So since it has no imaginary part the conjugate is simply itself? No changes?
Addez123 said:
That is true!
If a is real then ##a = a + 0i##. So ##a^* = a - 0i = a##.
-Dan
-Dan
Great!
But I still get the wrong answer.
$$4a^3 \int_0^{inf} x^3 \cdot e^{-2ax} = 4a^3 \cdot \frac {3}{8a^4} = \frac {3}{2a}$$
not 1/a as the answer suggests.
Addez123 said:
Great!
Ahhhh... I see the problem now.
You are looking for the most probable position. The expectation value is the average position.
What you want to do is find the where the maximum value of the probability density ##\Psi ^* \Psi## is.
-Dan
Note that for a non-negative real-valued function ##|\Psi(x)|^2## is a maximum at ##x_0## iff ##\Psi(x)## is a maximum at ##x_0##.
Good tip! I solved the ##\Psi^* \Psi## and got correct value though. Solved it again with your solution and it gave correct result too!
It's a good trick. In this case it doesn't save much algebra, but sometimes it can make things a lot simpler.
