Determine the signs (positive or negative) of the particle
  • Thread starter Thread starter wein7145
    Negative Particle
The original poster seeks to determine the signs of position, velocity, and acceleration for a particle based on provided figures. The context involves understanding motion in one dimension, with a focus on interpreting graphical representations of these quantities.
  • Participants discuss how to derive velocity and acceleration from graphical representations without explicit equations or labeled points. Questions arise about the interpretation of arrows in the figures and their implications for signs of motion. Some participants express confusion regarding the relationship between position, velocity, and acceleration, particularly at inflection points.
There is ongoing dialogue about the signs of position, velocity, and acceleration for each figure. Some participants have offered clarifications regarding the interpretation of arrows and the relationship between velocity and acceleration. Multiple interpretations of the signs are being explored, and participants are reflecting on their understanding of the concepts involved.
Participants mention the lack of explicit answers in the textbook for conceptual questions, which may contribute to the confusion. There is also a recognition of the need to understand the rules governing motion in one dimension.
wein7145
Background
The teacher doesn't teach we just do activities and have whole chapters worth of 20 mini assignments due every few days. Yes I did read the book.
1. Homework Statement
Determine the signs (positive or negative) of the position, velocity, and acceleration for the particle in
FIGURE Q1.6, FiGURE Q1.7 and FIGURE 1.8:
Figure 1.6
Figure 1.7 and Figure 1.8
2. Relevant equations
x=x(t) distance or position
__dx
v= -- velocity
__dt
__dv_____d^(2)x
a= -- or --------- acceleration
__dt_____dt^(2)
Ignore this "__" it is a space this doesn't accept spaces like some languages do...
For 1.6 I'm pretty sure Position is (negative) from starting point to origin
For 1.7 I'm pretty sure Position is (positive) from starting point to origin
For 1.8 I'm pretty sure Position is (negative) from starting point to origin
How can you determine velocity and acceleration which are derivatives from a line that has no equation or labeled points? I'm also aware of what is called inflection points where it changes from positive to negative. Are there rules I'm missing here? Would all signs be the same since this is 1D motion??
You can determine the velocity from the direction of the arrows.
The acceleration is related to the length of the arrows.
You mixed up the answers for 1.7 and 1.8
Remember that the y-axis is generally pointing upwards.
Thanks that helps a lot
You can determine the velocity from the direction of the arrows.The acceleration is related to the length of the arrows.
I thought it was just showing the velocity only not acceleration. Because the previous ones showed velocity with a direction bar ("v-bar") but looking at it again there are no markings. Yes so in conclusion: (That also makes sense from a number line point of view as -5 to -1 is still negative and 1 to 5 is still positive)
For 1.6 I'm sure Position is (negative) from starting point to origin
For 1.7 I'm sure Position is (negative) from starting point to origin (in math terms this is more positive but still negative)
For 1.8 I'm sure Position is (positive) from starting point to origin
Well about this little part
The position is strictly negative whatever way you look at it.
You being confused by the arrows.
The arrows point in the positive direction for 1.7, this means the velocity is positive.
Can you figure out the other two velocities?
What about the acceleration?
Remember, ##a=\frac{dv}{dt}## so you can look at how the velocity changes to determine the acceleration.
For 1.6 I'm sure Position is (negative), velocity is (positive), acceleration is (negative) from starting point to origin
For 1.7 I'm sure Position is (negative), velocity is (positive), acceleration is (positive) from starting point to origin
For 1.8 I'm sure Position is (negative), velocity is (positive), acceleration is (positive) from starting point to origin
Assuming all signs the same rule. Unless this is asking for signs at each part increasing and decreasing. Now I'm thinking the small arrow is decreasing and the larger arrow is increasing. Unless all arrows are just increasing? Again I don't even know the rules but this may in the end finally teach me them...
Whoops. Hopefully you can see the edits.
Almost there, you had the positions right in your previous post (negative, negative and positive). I was aiming at the small remark you made.
Why do you think the acceleration is negative in the first picture?
Doesn't the velocity grow?
Because in terms of derivatives usually they do the opposite sign at the inflection point.
For 1.6 I'm now sure Position is (negative), velocity is (positive), acceleration is (positive) from starting point to origin
For 1.7 I'm now sure Position is (negative), velocity is (positive), acceleration is (positive) from starting point to origin
For 1.8 I'm now sure Position is (positive), velocity is (positive), acceleration is (positive) from starting point to origin
Those answers are correct.
About the signs of acceleration, if the velocity increases you know that the acceleration has the same sign as this velocity.
You can easily see this from the kinematic equation ##v(t) = v_0 + a\cdot t## where I defined ##v_0## as the initial velocity.
As an aside, it's better to use speed when discussing the size of the velocity.
This helps you remember this distinction and avoid mistakes along the line.
Good Luck
J
Yes I agree speed and graphs with slope describe this concept better. (Although technically the slope is zero)
Going through my mistakes helps me remember and avoid making the same mistakes again. Thank you for the help. Strange how the book doesn't have answers to these conceptual questions but has answers to most of the odd numbered questions. I will have many more questions so be on the lookout for my journey into Physics! :)
