Determining average acceleration during point of impact
3 replies · 3K views
miles davis
Hello, new to the physics world, I am trying to self-teach through reading textbooks, videos etc and application.
I came across a problem I do not know how to begin to answer.
A dodgem car of mass 200g is driven due south into a rigid barrier at an initial speed of 5.0 ms^-1. The dodgem rebounds at a speed of 2.0m^-1. It is in contact with the barrier for 0.2s. Calculate:
a) the average acceleration of the car during its interaction with the barrier
b) the average net force applied to the car during its interaction with the barrier.
I am unsure which equations to utilise: F=ma, a= Delta v/ Delta t or kinematic equations
a) a = (-2-5)/(0.2) but for barrier unsure?
b) Fnet= 0.2 X unknown acceleration [/B]
Hello M, welcome to PF :)
a= Delta v/ Delta t is a good one for average a. Delta v is v before - v afterwards. Note that v is a vector, so the before and after have different signs in this calculation. a is also a vector and it should be clear that it points opposite to the original direction of motion of the car !
And you will do fine with F = ma in part b. So not what you write in your attempt: the 0.2 seconds have no place there...
[edit] Sorry, didn't see that it was a toy car. 0.2 kg is ok.
Again, F is a vector. Check the sign using your intuition!
Thank you BvU,
It is liberating receiving help from someone when navigating the minefield of physics.
Your guidance is perfectly clear, I am just unsure as to how to incorporate delta T here: if I were to divide the change in velocity (delta V) which appears to be -7 (in the opposite direction as you pointed out! :) ) by the change in time (0.2s?) (Final T - Initial T; 0.2 - 0) I end up with 35ms-2N, however this does not appear to be correct!
Apologies for my rudimentary understanding, I am still grappling with content.
Perhaps they want a different direction in the answer: you found ## -2 - 5 ## m/s per ##0.2## s = ##-35## m/s2 If I am correct. This is taking the 5 m/s South as positive. So the answer is ##-35## m/s2 South which you can correctly report as ##35## m/s2 North.
But if the program insists on receiving the acceleration in a southerly direction, then entering ##-35## m/s2 (with or without the S, I don't know) is the only way to get it to approve your answer.
( I'm deducing all this from your " this does not appear to be correct" -- without knowing if there is a computer program involved at all...)
For me your result is impeccable. No need for apologies; on the contrary: kudos for your wanting to learn !
