Determining Electric Potential
The discussion focuses on determining the electric potential V for a nonconducting sphere with a concentric spherical cavity, characterized by a charge density ρ. The potential is analyzed in three regions: (a) for r > r2, V is given by V = kQ/r; (b) for r1 < r < r2, the potential involves integrating the charge density and is expressed as V = (1/(4πε))∫dQ/r; and (c) for r < r1, the electric potential is zero. The key takeaway is the importance of understanding charge distribution and its impact on electric potential calculations.
  • Understanding of electric potential and charge density concepts
  • Familiarity with spherical coordinates and volume integrals
  • Knowledge of Gauss's Law and its application to spherical charge distributions
  • Proficiency in calculus, particularly integration techniques
  • Study the application of Gauss's Law to determine electric fields in spherical charge distributions
  • Learn about electric potential calculations for non-uniform charge distributions
  • Explore the concept of electric potential energy in electrostatics
  • Practice solving problems involving volume integrals in electrostatics
Students studying electromagnetism, physics educators, and anyone interested in mastering electric potential calculations in electrostatics.
Kennedy Poch
Consider a nonconducting sphere of radius r2. It has a concentric spherical cavity of r1. The material between r1 and r2 has a charge density p (C/m3). Take V=0 and r=infinity. Determine the electrical potential V as a function of the distance r from the center for (a) r>r2, (b) r1<r<r2, and (c)r<r1
ρ=Q/V
a) I have no idea where to start. Would my volume be just (4/3)πr3??
b) Total volume enclosed = (4/3)(π)(r2)3 - (4/3)(π)(r1)3
= (4/3)(π)(r23-r13
ρ=Q/V
=3Q/4(π)(r23-r13)
dQ= 3Qr2/(r23-r13)
V= (1/(4πε)∫dQ/r
Having trouble doing the integral...
c) There should be no electric potential inside
Welcome to PF;
"no idea" is not acceptable here - you have just done a section of coursework that should have given you some ideas ... go back and look again.
The volume of the sphere radius r is going to be ##\frac{4}{3}\pi r^3## all right - but what is the volume you are supposed to find? Your next answer suggests you are confused about this.
Lets say you had a ball of charge radius R and charge Q with uniform density - you want to find the potential at radius r < R from the center ... the rule (for spherical distributions of charge) is that the potential is proportional to the total charge inside the radius and inversely proportional to the distance from the center.
So you should not be thinking in terms of volumes at all, but in terms of how much charge there is.
You'll end up doing as volume integral but only because the maths is easier that way.
Outside of the sphere would we not just use V= ((1/(4πε))(Q/r) ?
That's outside the sphere.
For r > R, the total charge inside r is Q, so V=kQ/r
For r< R, what is the total charge inside r?
